Top seperated from bow..
thanks
The strip that holds the rear part of the top that you are describing can probably be repaired but you have to remove the rear curtain etc to access it so why not just look into getting a new top if you can afford one.
Its really not that hard to do yourself, just time consuming.
Either way good luck man our tops can be a pain in the *** sometimes!
the underside of the top. I used 3M marine adhesive
(white, fast cure) to reattach it and so far, so good.
I wouldn't get that stuff anywhere near a black fabric
but expect that the black windshield adhesive would
do just as well. Relieve the tension, remove any old glue
and give it a try?
How the headliner comes off, I dunno.
