convertible top goes up slow... 95 z28 need advice
well recently when i get ready to take the top down on the 95 z28 it will lift slowly.. sometimes i will have to help lift it down cause it stops sometimes.. i never maintained anything its my first convertible 95 z28 only has 20k miles on the car... is there anything i need to do or does anyone might now what the problem is???
check this before you spend big money. in my trunk on the left there is a flap of carpet that lifts up and view a valve with a triangle on top. turn the triangle and see if it fixs your issue. mines been golden for years!
Mine does not have atf, its almost clear, like mineral oil.
I had the same problem. I turned the valve to manual and put the top up and down twice. A couple drops of fluid came out of the motor, but I wiped it up, turned the valve back, and it works fine now.
