Which wheel / tire combo for lowered verts??
Wheels are 17x9" and 17x10.5"
Just wondering since convertibles are slightly heavier and I'm lowered on 1.25" springs and koni non adjustable shocks, will I have tire rubbing issues?
Thanks
Update - 4/30/17-wheels / tires fit good and car feels excellent.
I ended up going with 255/40/17 and 285/40/17 tires.
The car is a 2002 with usual boltons, any bigger tires would have been over kill for a Sunday driver.
Thanks
I am running OE Wheels ZR1 17x9 front with a 275/40/17 and 17x11 rear with a 315/35/17 rear. Koni yellow sport shocks with Hotchkis springs. SLP rear axle bump spacers with urethane bump stops.
I ran the same size on my hardtop and it would rub in the rear when loaded down on Hot Rod Power Tour. But only on bad dips especially at highway bridges. I did not roll my fenders though which I might do a little on the convertible. I did do the heater hose wrap on the springs and that helped a lot too.
Since you have a 255 front and rear I don't see where you would have a problem? Not even with a 275 since was an optional factory size.
Good luck!
Good luck!
Think the info is in my sig for the wheels (50mm bs) ... 315/30/18 rear 275's on the front.
Little light hammer work and some rolled fender lips in the back to get the rear tires to fit without rubbing.
I've got vette zr1's, 17x9 front, 17x11 rear, with 315-35/17 nitto motivo's on rear. I'm lowered on Strano springs with Koni str/t's, and I had to roll the fenders, remove the bump stops, and do a little hammering of inner wheel wells. Also installed adjustable panhard.
