Convertible Vehicles Enthusiasts | Information | Maintenance
Can the Spohn Torque Arm be use in Verts?
Old Apr 1, 2005 | 06:48 AM
Rok's Avatar
Rok
Default Can the Spohn Torque Arm be use in Verts?
Can I use this torque arm?
Spohn Torque Arm (adjustable LS1 w/long tube headers)
Old Apr 1, 2005 | 12:30 PM
AnotherScreenName's Avatar
Almost positive answer is yes, but not sure about the LTs. I would call.
Old Apr 1, 2005 | 01:47 PM
Rok's Avatar
Rok
I gave them a call and they said it would.
Old Apr 1, 2005 | 02:03 PM
bc56f100's Avatar
I have the same one in black and it works very well. I didnt get a chance to ride in the car with stock suspension, so I cant tell you how much of a difference it was. I can say that before I boke all the studs off at the track launching at 5500, I launched at 2000 and it went dead straight. Car came straight up pullin the front tires about a foot and a half. So I would definatly recamend it. It bolts in so easily also.
Billy
Old Apr 1, 2005 | 03:14 PM
All good to know, have to get one of these.
bc, do you have the one with the DS loop?
Old Apr 1, 2005 | 05:32 PM
TOPLESSTA's Avatar
Worked on my 98 vert with kooks headers
Old Apr 3, 2005 | 04:37 PM
00RedWs6's Avatar
I have that exact one on mine
Old Apr 5, 2005 | 10:55 AM
scalemaster's Avatar
I have the other style in mine cause of clearance problems
but the only diff is is that the front bar is flat
Old Apr 12, 2005 | 04:39 PM
bc56f100's Avatar
Yes mine has the drive shaft safetly loop.
Old Apr 19, 2005 | 08:36 AM
Rok's Avatar
Rok
scalemaster, what type of clearance problems did you have? I wondering because I have a custom y-pipe, and I've been told I might run into the same situation as far as it not fitting right.
Old Apr 23, 2005 | 08:07 AM
I have a problem with the Y pipe only not with my T/Arm
I have the SLP Y pipe and they hang to low and like I said look for the 1 with the flat bar
Old Apr 23, 2005 | 08:28 AM
Rok's Avatar
Rok
Ok, I've seen that one. I just got mine the other day with the curvey bar, so I'm crossing my fingers to see if it fits.
Old Apr 23, 2005 | 09:31 AM
well is ur car lower if it's not ur ok I know
and u will tell the diff I like mine alot
