Convertible Vehicles Enthusiasts | Information | Maintenance
Top trying to "fall" closed
Old Nov 2, 2005 | 03:44 PM
Alabama Cotton's Avatar
Default Top trying to "fall" closed
Hi all you guy's
When I close my top, when it starts closing, all is fine, then when it gets past the "vertical" it falls closed about 10 inches, and I have to catch it with my hand or it will hit the top of the windscreen.
Any ideas?????
Opening is fine, no probs.
Graham
Old Nov 3, 2005 | 11:17 AM
Shooter_Jay's Avatar
I'm thinking that's normal? Maybe busted springs or something though.
Old Nov 4, 2005 | 09:25 PM
ZeeVert's Avatar
That doesn't sound normal to me. Mine closes smooth and steady all the way. I have to pull it down the last 1/2 inch.
If it's happening to you, it must be happening to others. Good luck.
Old Nov 5, 2005 | 04:31 PM
in the closing motion, almost down it gains a little speed then slows again. totally normal I'm pretty sure. Maybe u'rs is worse tho.
Old Nov 6, 2005 | 05:04 PM
Mine gathers a loada' speed when past the vertical.
Im'e sure when I got it, it was smooth all the way, and like you said, pull it the last half inch.
BTW, I still have to pull it the last half inch to get to closed
Any more ideas ??????
Old Nov 7, 2005 | 07:59 AM
Dustin's Avatar
The reason why all of your tops are falling is because there is air in your hydraulic lines.
Old Nov 12, 2005 | 06:20 AM
Thanks for that,
How do I go about getting the air out of the hydraulic lines, to get tha smooth closing action again
Thanks
graham
Old Nov 17, 2005 | 01:23 PM
Black_97'Z's Avatar
Mine does that same thing as yours. I've noticed over the years it drops a little farther after the vertical point than it did when I got it.
Old Nov 17, 2005 | 01:27 PM
Dustin's Avatar
You have air in your lines, jusr bleed it and you wont have these problems, i posted a sticky on it.
