Convertible Vehicles Enthusiasts | Information | Maintenance
Car Audio Setups...
Old Jan 22, 2006 | 01:11 PM
BigT2002's Avatar
Default Car Audio Setups...
Anyone have subs at all in the trunk? I'm curious as to where to get the box and how big to go. I'm not looking for anything thats like house shaking but something that bumps when I want it to
Old Jan 22, 2006 | 04:07 PM
SSpeedracer's Avatar
https://ls1tech.com/forums/showpost....7&postcount=26
Old Jan 23, 2006 | 06:20 AM
JohnnyBs98WS6Rag's Avatar
Check out sig.
Old Jan 23, 2006 | 07:02 AM
cablebandit's Avatar
I have JohnyBs box and am very happy with it.
Old Jan 23, 2006 | 08:18 AM
musclehead's Avatar
Originally Posted by JohnnyBs98WS6Rag
Check out sig.
So you still selling them? If so I want one asap.
Old Jan 23, 2006 | 09:03 AM
TA guy's Avatar
Hey JohnnyB, Just curious, has anyone ever measured the frequency reponce of your box in car (and/or out of car)? I was just curious as to how much cabin gain there is in a vert.
Thanks, sorry to hijack the thread.
Old Jan 23, 2006 | 02:05 PM
Honda Hunter's Avatar
I want one asap as well. I wish they had something like that that used 12's or 10's instead but this would due. I emailed you. souljaslim4life@aol.com
Old Jan 24, 2006 | 06:59 AM
You have mail.
Shoot me an email or PM.
About the only equipment I have to do that is an old BSR 10 band EQ w/ a spectrum display, a calibrated mike and a pink-noise generator. Not enough resolution down low to do any good, so I haven't bothered to cart it out to the garage. "Cabin gain" is going to be kinda relative to how the subs are mounted (various box styles). I can attest that my box must be mounted IN the car for it to be effective, listening to it just sitting on the floor won't impress anyone. And there's probably 3-5dB more "cabin gain" w/ the top UP vs DOWN.
Old Jan 24, 2006 | 10:08 AM
quiet_storm98's Avatar
heres mine..i got it from subthump.com
Old Jan 25, 2006 | 07:15 AM
Subthump told me all they have is the passenger side stealth box. I didnt know they had anything else for verts. Was yours made for a coupe but fits?
Old Jan 25, 2006 | 08:26 AM
no they have ones for convertibles...they dont have it listed on the site but if you email them they will give you the link to it
Old Jan 25, 2006 | 08:38 AM
sweet.
Old Jan 25, 2006 | 08:47 AM
sweet.
it fits perfectly too and it was about $120 i think which isn't to bad
Old Jan 25, 2006 | 10:43 AM
BigT2002's Avatar
thanks for the help guys
Old Jan 25, 2006 | 12:13 PM
I emailed them. Feels good to know we have options.
Old Jan 29, 2006 | 01:45 AM
todddchi's Avatar
I have one of JB's sub boxes... setup with 4x RF stage 1 8" subs. As of now it is underpowered, I am sending only the 150 watt RMS / 300 peak channel of an Alpine V12 amp to all four subs.
With the top up, the sound is very good. It is not as strong as in a coupe, but this 4x 8" setup is similar in sound to my previous 2x10" bandpass setup in my previous coupe. So plenty of bass for quality, you just won't be shaking those around you.
With the top down, well, you lose alot. It is still tons better than w/o the sub setup of course, but the bass volume takes quite a hit. And if it is attention you want, a balanced system with bass in a vert is of course a lot louder than in a coupe to outsiders.
I am in the process of tinkering with a few different concepts with this box, that I think will help the situation by a large amount.
1.) The internal volume you have to work with is .18 cubic feet for each sub. If you are not a basshead it would more effective to couple the enclosures to net .36 cubic feet per sub and tune the port from there. In this arrangement I'm sure you could mod up a slotted port tuned to 40-60 Hz.
2.) I have four subs, so I've modded my box with 3/4" plates to fabricate a 5" slotted port of about half the original port. The "stock" box has just a slot which is basically a 8 square inch x 1 inch port. With this mod I have close to a 3 square inch x 5.5" slot port. By the math this drops the port frequency from around 200 Hz to about 80 Hz. I haven't had a chance to evaluate it in car extensively, but it is quite a difference, and there is still no port noise. I suspect you could reduce the port cross section even more but this seemed on the small end already so I stuck with about 3" effective cross section. Once spring is here I am going to feed the box more power and try out some other port tunings.
Regardless, if you are really pushing the subs hard, you'll probably want to make sure you use the subsonic filter on your amp - or if you don't have one get a pair of 30 or 50 Hz Fmods to keep your subs alive. partsexpress sells them for about 25 bucks.
3.) The last item is something I am forced by winter to wait awhile to try. The box relies upon getting sound through the top, which is what is good about JB's box. The slots are low mounted so the sound does a decent job of snaking it's way through the shield of the dropped top. JB made the box shape to mimick the profile of the plastic seperator, which I think is the right way to do it. However I've noticed that every little bit you can pick the top up off the shelf, opens up a direct path to the ports and makes a huge difference. So what I am going to try is to fabricate a couple small spacers that will keep the top from sitting on the shelf, lifting it by a half inch or inch or so. I think with the right materials, you should be able to keep the top off the shelf a little bit without danger of damaging the top or glass. But I really need nicer weather to mess with this, and it requires a good bit of thought because of the fragility of the top material and glass. I am currently favoring using some foam rubber pads.
Anyone with a sub in their vert trunk can evaluate this very easily. Just drop the top, crank it up, and then crawl in the back seat and lift the top off the shelf an inch or so - it makes a huge difference.
JB's box is very nice, he was excellent to work with and delivered as agreed. For a vert I think this is hands down the best option and am surprised they are not more popular. I am just a bit of a fidgeter and want to see how I can make my system stronger.
If you want to build your own, then I think the next best thing would be a fabricating a plate again mimicking the factory seperator, and equipping it with free-air subs, which would benefit from my thoughts in point 3 above. Actually any setup could benefit alot from point 3 - even if you go the battle ax approch of just dropping a huge box in your trunk.
I need every bit of that tiny trunk, and don't want my trunk lid or trunk rattling - so JB's approach was best for me.
Old Jan 29, 2006 | 08:31 AM
BigT2002's Avatar
Thanks for the writeup Todd
I'm not looking for attention getting, if I wanted that I would delete the rear seats and put in a makeshift thing for two 12's or something. I just want the bass to go somewhere so I can turn it up a lil louder than I can already. I've already changed out the deck and the speakers in the car, I just need the subs
I wouldn't mind getting that subthump but I'm sacrificing my entire trunk for it and I'm not too sure about that right now...maybe when I get to SC I'll think about it
Old Jan 29, 2006 | 12:08 PM
BJM's Avatar
BJM
I was really keen to still have some space left over so I made my own enclosure, show here. Its not shown in place but its upholstered and matches the trunk nicely.
Old Jan 29, 2006 | 11:07 PM
todddchi's Avatar
If you wanna keep your trunk then JB's box or a similar concept is the only way to go. You're going to end up spending a little more, most likely, but to me an extra $100 to keep my trunk was worth it.
Old Jan 30, 2006 | 09:37 AM
I'd guess closer to 9dB. I've had several people comment on how clear the subs are with the top down.
