Convertible Vehicles Enthusiasts | Information | Maintenance
Top coming up slower....
Old Nov 14, 2006 | 06:10 PM
BigT2002's Avatar
Default Top coming up slower....
Just noticed it today that the top is taking a lot longer to come back down to get locked up on the top of the windshield. Anything I can do to keep the life goin on it?
Old Nov 15, 2006 | 07:51 AM
JohnnyBs98WS6Rag's Avatar
Make sure the top pump is full of fluid, these pump systems are notorious for leaking. Last I heard, GM recommends "mineral oil" for fill. Pump is located on driver's side behind the rear wheel well in the trunk (under carpet). Once you top off fluid, you may need to cycle the top once or twice to purge the air, then top-off fluid again (the pump has LOW and FULL marks on the resivoir).
Old Nov 15, 2006 | 09:55 PM
BigT2002's Avatar
thanks man I'll check it out soon as I get off of work
Old Nov 16, 2006 | 04:36 PM
ino's Avatar
ino
When mine was slow it was because I did not have the car turned on.
Old May 17, 2007 | 09:51 AM
RCowan's Avatar
Turn the valve to manual operation. Manually lower and raise the top a couple of times to equalize both sides. Turn back and try it out with the switch.
