Convertible Vehicles Enthusiasts | Information | Maintenance
Rear Shocks
Old Jan 19, 2007 | 07:08 PM
ZFan88's Avatar
Default Rear Shocks
Where's the top bolt for the rear shocks? I don't want to break something on accidently looking for it..like those stupid plastic panels lol
Old Jan 19, 2007 | 08:10 PM
Roadhouse's Avatar
Pull down the rear seat and you'll need to look for perforated "accesses" in the carpet. Open them up, pull out the insulation and you should be able to see the bolts.
Old Jan 19, 2007 | 08:30 PM
ZFan88's Avatar
Cool, thanks. I didn't want to tear things up lookin for it
Old Aug 16, 2007 | 12:33 AM
Spellbound's Avatar
I was going to post up this very question. Search works! lol.
Old Aug 16, 2007 | 12:27 PM
99'CajunFirehawk157's Avatar
Is it bolts or a stud w/a nut on the top mounts? And these are located in the rear "shelf" area just behind the seat back, correct?
Old Aug 16, 2007 | 12:58 PM
jimmyblue's Avatar
Moderator
Stud with nut, you need a small metric wrench to hold the flat on
the stud. I think 7mm but it's been a long while since I messed
with them. If it looks at all rusty then give it some Rust-Eater
and a while to loosen up, the stud-flat isn't much to grip on.
Anti-sieze is when it goes back together.
They're inset in the wall behind the seat, in pockets, and foam
rubber biscuits hide the stud ends.
Old Aug 20, 2007 | 12:08 PM
Exclamation
To undo top studs/nuts on rear shocks on vert fbodies:
1) fold down rear seat, look on both sides for perforated carpet, you WILL need to cut it thru, it is only perforated, cut thru then pull flap back. Pull out foam "silencer" material
(see pics)
2)use small crescent to hold shock stud, use open end wrench on top nut (15mm?), loosen nut. Undo lower stud, remove shock, replace in same fashion. Apx time to do both; 1 hour +/-
(see pics)
Attached Thumbnails Rear Shocks-hot-044.jpg   Rear Shocks-hot-048.jpg   Rear Shocks-hot-051.jpg   Rear Shocks-hot-047.jpg   Rear Shocks-hot-050.jpg
Old Aug 20, 2007 | 10:41 PM
bradl1982's Avatar
This should be stickied at the top of the vert section. I searched forever on here when I did my shocks.
Old Sep 7, 2007 | 08:23 PM
Jimmyz's Avatar
Excellent info. !! Putting Koni's on next week and I had no clue this was what I had to do.
Old Sep 7, 2007 | 09:11 PM
Rears are SUPER EASY , now the fronts are a whole different story...
Old Sep 9, 2007 | 02:06 AM
ZFan88's Avatar
Fronts are easy if you have some good spring compressors. mine sucked and took an hour to compress each side with a wrench
Old Sep 11, 2007 | 09:01 PM
bradl1982's Avatar
And if the bolts aren't rusted tight where they need to be cut off.
Old Sep 11, 2007 | 09:04 PM
If the front shock, upper nuts arent rusted then you wont need to cut them off...just unbolt. Rears are never rusted.
