help... convertible top not going down...
Since you said you could raise it but not lower it with the motor it sounds like you don't have a burned out motor, broken linkages, or anything expensive to worry about.
My guess is an air pocket in the lines. Check all your lines. They are semi-transparent so you can tell if there is an air pocket in them. Try to lower and raise the top with the switch a few times, not fast but hold the switch for a few seconds each way as if you were lowing it all the way down or raising it all the way up. This should get the fluid moving in the lines and lube the motor up pretty well.
As long as you don't hear the motor bog down you should be ok. The stress on the motor is actually in the lowering process, not the raising process. And I can't imagine a top motor going out after only 12 years. I had Cadillac convertible motors that ran for decades.
Also, it doesn't hurt to check the fluid level. GM is now recommending mineral oil.
And with it not lowering,I'd check switch first.
