Convertible Vehicles Enthusiasts | Information | Maintenance
Rear seat delete in vert
Old Aug 13, 2007 | 12:33 PM
GXPPOWER's Avatar
likewise. the air turblence just by having the t-tops open is enough to lose performance.
mabe not much but when we are all trying to gain 1 hp here and their. pressing the top up button makes the most sense
Old Aug 13, 2007 | 03:40 PM
2000TurboVert's Avatar
I was wondering, if there is a roll bar that can be installed, and not welded and stuff!
Anyone know of aynthing?
Old Aug 13, 2007 | 09:36 PM
quiet_storm98's Avatar
one of my friends had a bolt in rollcage in his...the only problem was that when it was installed they accidentally drilled into his brake line, after that he welded it in
Old Aug 14, 2007 | 03:58 AM
HASTINGSRJ's Avatar
www.wolferacecraft.com bolt in rollcage, check my previous post on the first page. I have a bolt in 6 point cage......you do have to drill holes through the floorboards
Old Aug 14, 2007 | 09:54 AM
InsaneAuto86's Avatar
Originally Posted by HASTINGSRJ
Your AC compressor weighs more than your back seat does.
I took the back seats out after this pic, but heres whats back there
My a/c compressor is gone, along with my heat and everything under the dash. The padding and sound deadener under the carpet is gone too. Im going to a metal shop this week to see about getting that plate made. I'll let everyone know how it turns out.
Old Aug 14, 2007 | 09:44 PM
so when you drilled yours you didn't hit your brakeline right?? I still dunno how my friend did that, he had the same rollcage
Old Aug 15, 2007 | 05:01 AM
HASTINGSRJ's Avatar
the brake lines are not in the way if you drill properly. I didnt have any problems installing mine. There are plates that go under the car as well that the cage bolts to. Plenty of clearance for the brake lines. If I was home I would take pics for you, but I am in Iraq, sorry.
