Losing Battle?
My 02 Z /28 convertible running full weight spare tire & jack with nothing but a lid & Manaflow replacement muffler runs 13.20's at over 105 MPH & I weigh in at over 245 lbs. Sounds like you got a lemon thats out of tune or something.
Instead of costing two or three hundred for a couple a tenths now your lookin at $800.00 to $1500.00 for that 2/10's .
For my money a blower is the way to go on the street with 4-6 lbs. boost , even then you may have a problem with pump gas . On the strip its hard to beat a Turbo. Course there's always laughing gas but you may have the same problem with pump gas with nitrous also . Most stock LS1's with nitrous should get into the elevens I would think. Good luck !
Don't see the problem... And 4-6 psi would not only create no problems but would be a waste of time and money as well IMO... Boost should at least be 8/9 to make FI worthwhile IMO... If you're going to run 4-6 psi, you might as well get a mild H/C NA set-up and spend less than half the money.
So we weigh a little more, just add 30 rwhp problem fixed. I love my 'vert.
I am going H/C route and see what happens. I totally agree with 4-6 psi is a waste. I think if your going to spend the money anyway go big with FI. Thanks everyone.
Ok brother , if you think 4 to 6 lbs. of boost is a waste on a street driven daily driver go ahead , get yourself some 8 lbs of boost. You will soon learn the meaning of the word WASTED when your engine disagrees with you & your pump gas . Just like all novice bench racers , they all think bigger is better. Bigger carb. on the street,bigger cam, bigger exhaust pipes,more boost , etc. etc.
Live & learn !
And YES, to turbocharge/supercharge your car (with how expensive it is) and get ~400 rwhp on 4-6 psi is a waste of money and time considering two things:
A. The stock block handles AS A LOW ESTIMATE 500 rwhp on pump... What limits it is the weak pistons NOT THE GAS... With a forged set of pistons, you can do 700 rwhp on pump on a stock cube 346... Ask me how I know. With the stock pistons disintegrating somewhere after ~550 rwhp, 8 psi is an agreed "safety" level to keep the stock pistons intact...
Has NOTHING to do with the gas.
If you added race gas ro run higher boost, your stock pistons would still disintegrate past the same levels due to weak ringlands even with zero detonation. BTW, there are some brave souls in our FI section (NOT RECOMMENDED), that run over 10 psi and make over 600 rwhp on pump gas on stock bottom end, stock heads, and stock cam... One guy ran this way for a year before finally blowing up due to a very expected piston failure.
B. A mild NA H/C set-up can do ~400 rwhp and more for much less money and hassle than an FI set-up for TONS of money LESS.
If you're running 4-6 psi, that's a waste of an FI set-up on an LS1...
BTW, I have never run race gas in my car nor will my car EVER even see race gas.
So live and learn what dude? My car has NEVER ONCE been down on the side of the road? He's getting the right advice obviously and is going with it from people who've been at these crossroads before.
Live & learn !
I have a blown 57 chevy, I have also had a few cars in my time. The point I was making and others was H/C is cheaper than 4-6lbs of boost to make the same power.
...i love your car too.
