Convertible Vehicles Enthusiasts | Information | Maintenance
Help! I can't get it up!!
Old Aug 19, 2007 | 12:50 AM
chipabba's Avatar
Default Help! I can't get it up!!
My top that is. I need to lift it up by hand to the half-way point before the motor takes over for the rest. I checked the pump in the trunk and it appears dry. I have yet to check the hydrolics behind the rear speakers for a leak. Any suggestions? (I mean besides Viagra)
Old Aug 19, 2007 | 05:41 AM
BobDoLe's Avatar
what do you got against viagra, buddy?
Old Aug 19, 2007 | 01:38 PM
9silverbird8's Avatar
It's dry? Filler up.
Old Aug 19, 2007 | 10:14 PM
chipabba's Avatar
I've got nothing against viagra. My doctor once prescribed it for a bad sunburn I got last year. He said it was to keep the sheets off my legs
Old Aug 20, 2007 | 08:27 AM
DANOZ28's Avatar
i hope your fix is as easy as mine was, in the trunk on the left was a flap ,under flap is a valve make sure its pointed in the correct position. mine wasnt and my top needed my help. once corrected works perfect!
Old Aug 21, 2007 | 02:41 AM
chipabba's Avatar
Isnt this supposed to be a closed a closed hydrolic system? If I do "fill it up", what with and where?
Old Aug 21, 2007 | 12:31 PM
JohnnyBs98WS6Rag's Avatar
Isn't there a sticky somewhere on this w/ pics......?? If not, there needs to be.
Pull up the carpet on the driver side trunk to expose the pump. The proper fluid level marks are on the white/clear resevoir about midway up. If low, fill it up to the marks w/ mineral oil or 10W SAE oil (as I've recently seen posted). The top of the pump resevoir has a fill plug, remove it w/ an allen wrench and use a funnel to fill w/ fluid. Put the plug back in, cycle the top up/down a few times to flush out any air in the system. Top off the fluild again.
