Convertible Vehicles Enthusiasts | Information | Maintenance
vert gears?
Old Sep 7, 2007 | 06:38 PM
95hitam6's Avatar
Default vert gears?
i have a 95 ta vert m6, and i've read that all lt1 m6's have 3.42 gears, well i check my glovebox door today and the code read gu5 (3.23), any of you guys seen this? **** sucks.
Old Sep 9, 2007 | 03:39 AM
ws6dude's Avatar
Throw some 4.10s in it.
Old Sep 10, 2007 | 02:52 PM
JohnnyBs98WS6Rag's Avatar
Are you sure that doesn't read "GU6"?? If you are correct, this would be the first I've heard of a 4-th gen V8 f-bod M6 w/ anthing other than 3.42 gears, something sounds fishy.
Old Sep 11, 2007 | 08:27 AM
todddchi's Avatar
Yah, it sounds very strange, because 3.23 M6's were not built. They just weren't. There isn't even a factory calibration for the speedo that would work.
What's your cruise rpm at 60 in 6th? I think it's impossible your car was built as M6/3.23.
Maybe an M6 swap car, salvage glovebox door, something like that maybe?
Old Sep 12, 2007 | 10:46 AM
1sikws6's Avatar
i have 4.30s
Old Sep 12, 2007 | 01:26 PM
gyrene2003's Avatar
i had 3.23s but im an A4 car. Just did a set of 3.90s.
Old Sep 13, 2007 | 06:46 PM
kdolson212's Avatar
I ordered my 2002 M6 with 3.73 gears.
Old Sep 17, 2007 | 02:41 AM
95hitam6's Avatar
idk guys i tried hard to look at the box sticker and see if it was a faded 6 but it clearly looks like gu5. i got the car a few months ago and the trans had been newly replaced but he didn't indicate that it was swapped to m6. as far as my rpm in 6 gear at 60, well i want to say 17-1800 but don't quote me sometimes it won't go into 6 unless im going faster. i'll check that tomorrow, also when asked (the seller) he told me it had 3.42s only after i learned about codes, i checked.
Old Sep 17, 2007 | 05:19 PM
Alt's Avatar
Alt
Do the rest of the codes match the car? You could have a junkyard replacement door on car.
Old Sep 17, 2007 | 07:48 PM
Ragtop 99's Avatar
Ordered from whom?
Old Sep 18, 2007 | 01:23 AM
95hitam6's Avatar
its in the glove box not the door, and the only codes i know right now are the rearend codes "gux", i'm on my way to work so i'm a check the 60mph rpm in 6th gear.
Old Sep 18, 2007 | 04:10 AM
bww3588's Avatar
sounds like you have a junkyard glove box door, 1993's were the only 4th gens to have the RPO sticker in the glove box that i know of. after that, they started putting them on the drivers door.
Old Sep 18, 2007 | 04:54 AM
95hitam6's Avatar
my door has a sticker but no codes just car info like date manufacutred, curb weight etc. and my rpm's were at 11-1200 at 60mph in 6th, hows that sound, its hard to get into 6th doing less than 65, i have to speed up then drop it into 6th and slow down lol.
Old Sep 18, 2007 | 05:06 AM
bww3588's Avatar
its a toss up. at 60 with 3.42's you should be right around 1300-1400 RPM. maby the LT1 cars had the RPO's in the glove box till 96. not sure.
Old Sep 18, 2007 | 05:08 AM
Alt's Avatar
Alt
Oh yeah I forgot about it being a 95. It is the glovebox my apologies.
Old Sep 18, 2007 | 05:26 AM
95hitam6's Avatar
all good thanks for the info, yeah its right below 1500 rpms, on another note i can start the engine without pushing in the clutch, normal?
Old Sep 18, 2007 | 07:29 AM
Lets stop beating around the bush. Please confirm:
A) Does the VIN on the glovebox decal match the VIN under the windshield?
B) Does the glovebox decal have MN6 (RPO for T56 6-speed MT)?
You've already confirmed you have GU5 (3.23) and not GU6 (3.42). If all of the above is true, then you have a factory freak.
If A) is false, B) is probably also false too. The govebox doesn't match the car.
If A) is true and B) is false, then your car has had it's transmission swapped from an A4 to a M6.
Old Sep 18, 2007 | 10:22 AM
todddchi's Avatar
John's right, there's a lot of crap in this thread.
I think the guy who "ordered his 2002 M6 with 3.73's" should post up his build sheet. Because apparently he is the only 4th gen owner with enough pull at GM to get them to build a unique configuration and create a new factory PCM file. Must have been an expensive option.
A few weeks ago I had a 20 minute argument with a guy who insisted his '99 A4 WS6 had 3.90's from the factory.
Old Sep 18, 2007 | 04:27 PM
95hitam6's Avatar
its been swapped, vin's match but the trans code is m30, a4 4l60e, case solved thanks for pointing out the obvious.
Old Sep 18, 2007 | 08:55 PM
My pleasure. Here was my first clue:
NOT normal. Whoever did the trans swap omitted the clutch-starter interlock switch.
