Convertible Vehicles Enthusiasts | Information | Maintenance
Rollbar Advice
Old Nov 5, 2007 | 02:08 PM
mermel's Avatar
Default Rollbar Advice
I would feel better about driving my 'vert if I had a rollbar installed. However, looking at a lot of pics on the site, I'd rather have only one bar that went across as opposed to one that also attached behind the rear seats, don't like that look. My questions are the following...
- Is it harder for passengers to get into the back?
- Is it a bolt or weld job?
- What kind of shop should I go to for this kind of work?
- About how much should I expect to pay for the rollbar itself and installation?
Old Nov 5, 2007 | 04:16 PM
import slayer's Avatar
check this site out and look under f body roll bars
http://www.wolferacecraft.com/
Old Nov 5, 2007 | 11:22 PM
mermel's Avatar
Nice, but they don't have a 2-point rollbar which is what I'm looking for. I don't want connectors in the back, only on the sides.
Old Nov 6, 2007 | 05:00 AM
2001WS6Vert's Avatar
A two point would not have enough strength to offer any safety. It would just fold over. You could weld or bolt one in, but welding would be stronger. You would have to find a shop that specializes in roll bars/cages (tube bending/tig welding). If you don't want the rear bars you could at least tie into door bars for a little extra support.
Old Nov 6, 2007 | 10:42 AM
99'CajunFirehawk157's Avatar
I saw one I would have been down for but I cant figure out who makes it, I am kind of like you, I want one but I don't want to loose the usability, then again, I don't get into situations on purpose where I would be in a situation to need one per say...I drive slow for plenty of show...
Old Nov 6, 2007 | 12:48 PM
mermel's Avatar
I don't drive fast either, but nothing can stop a Ford Expedition from running a red light at 60 MPH and rolling my car over 6 times (happened to a friend in his 2003 Sebring convertible, 2-point rollbar saved his life, car was salvageable too).
Old Nov 6, 2007 | 02:48 PM
Thats why you not only have to watch how you drive but how everyone else drives, but like you, a lil insurance would be a good thing...
Old Nov 6, 2007 | 03:05 PM
mermel's Avatar
My neighbor has a 2000 Cobra convertible with a 2-point rollbar which he says is fine for most types of rolls. His is bolted in. The place where he got his installed no longer exists, so I'm still kind of lost.
Old Nov 7, 2007 | 12:47 AM
Numba1Stunna's Avatar
somethime like this http://www.afterthoughtsauto.com/cafilibar1.html ? cant see it helping much tho
Old Nov 7, 2007 | 08:52 AM
Negative, those are strickly show and must be with some sort of ligts, I suspect a hi-mounted third brake light...that in metal would be kewl though
Old Nov 7, 2007 | 09:47 AM
mermel's Avatar
I thought it was metal inside. I read that it's a 1 1/4" steel tube with a 1/8" thickness covered in vinyl...
Old Nov 8, 2007 | 11:02 PM
Corvettekid82's Avatar
Those light bars do not add any structural support to the cars. They're for looks and added 'safety' of a high mount stop light. I think they look good on mustangs, but they dont flow with the lines of the F-bods too well.
Old Nov 9, 2007 | 11:21 AM
Ragtop 99's Avatar
RK sport made a 2pt rollbar.
IMO, I'd find a way to go 4 pt, even if you custom build the 3rd and 4th point further down on the main hoop below eye level. My 4 point allowed me to walk away from a bad side impact smack up.
If you go 2 pt; I'd take the rollbar through the floor and weld it into the subframe. That would survive a pretty decent side impact and not twist with the floor pan in a rollover. Having weld in subframe connectors also helps in a side impact if you hit a stationary object such as a pole.
Old Nov 10, 2007 | 07:18 PM
Check this out:
I pm'ed the owner to ask what brand that is...stay tuned!
Old Nov 10, 2007 | 10:51 PM
The owner informed:
"Wolfe craft main hoop and i made everything else.Its a 4 poiint that ties in to the main body by the rear speakers.Thanks josh"
Old Nov 16, 2007 | 02:49 PM
the light bar...
http://www.classicdesignconcepts.com...splay/520.html
Old Nov 18, 2007 | 03:26 PM
joshtownsend's Avatar
true ...true
Old Nov 19, 2007 | 03:37 PM
00Camary's Avatar
+1 on that notion. I hate light bars on f-bod verts
Old Nov 19, 2007 | 03:41 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
2 point bars will do NOTHING in a ROLLOVER...NOTHING.
