my 9" is slapping my floor board!!
Any one else have this problem? Before i broke the 10 bolt i was always getting this horrible sound on the 1-2 shift, bad clunking noise. I had replaced the torque arm mount like most people said. Well, it still happens. Me and a buddy were under the car one day after looking over to possibly see what it is. The damn torque arm bracket is actually hitting the car on really hard shifts and some bumps(very few) i have heard the noise also. You can easily see where it has been hitting, theres a nice shiny spot with a dent in the center. Could this be my shocks getting old? Will new ones help this? The car has got alot of miles, just over 100k. I thought the noise was my getting ready to break the 10 bolt, well its gone and it is still doing it. Some one with a 9" in a vert chime in here
Same problem here. Happens most often on a hard 1-2 shift or going over a railroad crossing under acceleration. Sounds really nasty. I have not gotten under mine but will be very interested in feedback from others that have resolved this.
Its very common, everyone with a 9" will report the same problem.
Solution- Find where it is hitting the floor and take a large hammer and dent the floor/tunnel for "clearance".
Most 9 inch tq arm mount brackets have 2 sets of holes, the inner most set need to be cut off and the tq arm will move over towards the center of the car parallel to the driveshaft. This will stop.
David
David
Also one thing to remember is most of you are running lowering springs. The lower the car goes the closer the torque arm will get the tunnel. On a stock height car our torque arms will lightly touch the tunnel area, after a few launches it clearances itself and there is no noise. But on a lowered car it will need clearanced more.
Hope that helps!
Ryan
wow, its nice to hear i am not the only one. I was thinking it was possibly blown shocks. I have been getting this annoying squeak coming from back there ever since i put the 9" in. I was thinking it was the panhard rod, since i had to grind the damn thing down to fit the bracket on the new rear. I think the rod and the bushing is exactly the same length so maybe the rod is grinding on it? I dont know its pretty annoying tho
Hope that helps!
Ryan
This is the same solution moser gave to me when I called them about top bolt where torque arm mounts to rear hitting up in the tunnel.
