Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
vararam installed / check engine light on
Old Nov 5, 2008 | 02:48 PM
QUIKSILVERZ's Avatar
Default vararam installed / check engine light on
getting codes 0171/0174. This show that banks 1 and 2 are lean. Does this mean i need a tune or do i have a air leak somewhere? I have put 100-200 miles on the car and the light/codes just showed up today. I have cleared the codes out twice now. I clear the code out, drive the car, turn it off and as soon as i restart it i get the above codes.
Old Nov 5, 2008 | 05:19 PM
Ragtop 99's Avatar
Did you install the spacer? If you did, my guess is that it is not sealed tight and air is leaking in.
Old Nov 5, 2008 | 06:24 PM
Ragtop 99's Avatar
Also make sure that you did not put the MAF sensor on backwards.
Old Nov 6, 2008 | 02:58 AM
Quik Z06's Avatar
Yeah I say you probably got a leak. I would also disconnect the battery for a few mins to see if that helps reset the codes (after you clear them, maybe it will keep them off) I dont know if that works on the Vette.
Old Nov 6, 2008 | 08:19 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Definitely sounds like you have a leak somewhere.
Old Nov 6, 2008 | 08:28 AM
allngn_c5's Avatar
I too have the VaraRam and am very surprised that you are getting any codes. I have never had a code. Go back and check all connections. Is everything tight ?? Best of luck.
Old Nov 6, 2008 | 12:30 PM
HWY HNTR's Avatar
This is normal from the increased air going in. 2 codes, lean fuel trim on bank 1 and 2. You need a tune my friend to compensate for the added air. Same exact thing happened to me.
Old Nov 6, 2008 | 09:12 PM
Did the idle relearn today (pulled fuses 16/23) and drove the car a lot today. No codes/check engine light on. The car still has the stuble/bucking at low rpm, light throttle, and slowing down. Everything is tight and can not find any leaks. I am going to hold off on the tune until i get the long tubes.
Old Nov 11, 2008 | 10:15 AM
i removed the inlet tube and maf again and tighted everything down tight! It helped but did not fix it. I think it is leaking around the TB. I am ordering vararams new power duct today. I hope that it helps. If not i can live with the small bucking until spring when the headers/tune go on the car.
Old Nov 11, 2008 | 07:21 PM
Ragtop 99's Avatar
You try shooting a little starter fluid around it. If it picks up any rpm at idle, it is a leak. Any chance you damaged a MAF wire during the process?
Old Nov 12, 2008 | 02:37 AM
thanks for the tips. i will try these when i install the new air bridge.
Old Nov 12, 2008 | 07:56 AM
ls1290's Avatar
The MAF and PCM should be able to compensate just fine for the extra air flow from the Vararam. The LTFT take a while to settle down after a 'big' change to intake air flow. That is why there are called long term fuel trims. I am still betting that you have a leak somewhere, have been running lean for a while, and no the computer is throwing the codes.
Old Nov 12, 2008 | 09:53 AM
greentahoe's Avatar
I would say you got a leak too. Something isn't sealed between your MAF and engine or your MAF was damaged. My car was still very rich on the factory tune with the vararam
Old Nov 12, 2008 | 11:14 AM
allngn_c5's Avatar
Amazing !! No codes ever after my install. I started it up after the install was complete, drove her around normally for 10 miles or so then hit the expressway to go fast see if there was any kind of difference. Seemed like she pulled harder up top then before.
I really hope you get your issues resolved. Just sucks when a simple install creates issues.
Old Nov 15, 2008 | 12:19 AM
got the vararam power duct in and installed today. nice product. all the couplers fit tight, plastic feels/looks better than the vararam cai lol, the car idles great and no check engine light. Have not driven it yet though.
Old Nov 17, 2008 | 03:24 PM
Good news is the bucking is gone and the car drives perfect.
Bad news is the damn check engine light is back.
I DID THE IDLE RELEARN, TIGHTED EVERYTHING DOWN, CHECKED MY FILTER, TUBES, ETC. EVERYTHING IS TIGHT. AND CLEARING THE CODES OUT ONLY LAST FOR ONE OR TWO STARTS. LOOKS LIKE I MAY HAVE TO GET IT TUNED TO KEEP THE CODES AWAY.
Old Nov 17, 2008 | 03:49 PM
Ragtop 99's Avatar
Is it the same codes? If the car is driving properly that is a good sign.
Old Nov 18, 2008 | 12:15 AM
Yea the car is running perfect. Just like stock lol. Same codes as before.
Old Nov 18, 2008 | 11:01 AM
greentahoe's Avatar
Do you know someone near you with HPTUNERS that could at least log it? Weird
Old Nov 19, 2008 | 07:45 PM
Thinking about just getting a tune or going back to stock until i get my long tubes.
