All the help I can get
if you do get a auto a torque converter and new rear will amake the biggest SOTP difference and then start adding heads, cam, headers.
w/ a manual headers and a cam w/ make a bigger SOTP difference and then go onto heads a rear
alot of guys a do the rear swap and bolt on a Super Charger and coming really really close if not into the 11's on the track
oh the power i don't think that there is a big differnce in power from year to year except when they came out w/ the Z06 option, but a 01 and up already have the updated LS6 intake on w/ is a plus since they run like $500
as for nitrous alot of guys use it and it's safe as long a use your head, i seen some guys putting a 250+ shoot into a stock engine and wondering why the piston rings and stuff where blowing out.
last but no least i'll post a pic of mine, it's a 00 FRC w/ the mag wheels
The FRC is about 75lbs lighter than the coupe. The Z06 lost some more weight because of the thinner windshield and exhaust. The additional stiffness comes from the crossbar under the rear window which is also present on the convertible.
Automatics have either a 2.73 rear axle or 3.15. Manual transmission cars have 3.42.
97-00 are rated at 345hp, 01-04 are 350hp, 01 Z06's are 385hp, 02-04 Z06's are 405hp.
Traction control is standard on all C5's, active handling became optional in late 98 it was revised and made standard in 01.
The Z51 suspension package is desirable and includes a power steering cooler, different shocks, springs and sway bars. Most people do not like the F45 adjustable suspension, but it redesigned for 03 and is the F55 option. It is said to be better than the Z51 suspension.
There are a lot of options available. Take a look at chevrolet's website, most options have been available since '97.
Eric
I really do like the look of the magnesium wheels and would probably buy them if they were wider.
Eric
I have a 4.10 rear end waiting to go in my own car.
Eric
And personally, i think the magnesium wheels are fugly as hell. They look like retarded Y2k rims to me personally. I just dont like the way they "fit" together. I'd rather have Y2ks or Z06s if im getting stock C5 rims. But, the wheels shouldnt make a big difference (outside of price difference between mag wheels and non-mag).
