Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Cam Install Question
Old Dec 10, 2008 | 09:37 AM
VolatileC5z's Avatar
Default Cam Install Question
Hey Folks,
Putting the vette away for the winter this weekend and I'm going to be tearing apart the engine and replacing most of the top end. I want to put a cam and possibly heads (if I can find a set of used heads cheap enough). Is there anything special that I need in order to do this? Are there things like if I'm 1mm off on something the engine will blow (regarding cam install), etc? Any tips/links to guides/suggestions would be appreciated. I will also probably be doing lifters, valve springs and rocker arms.
Thanks.
Old Dec 10, 2008 | 11:03 AM
stangbangin69's Avatar
everything you need to know is right here bro!
http://www.ls1howto.com/
Old Dec 10, 2008 | 11:28 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Excellent site. I have used a lot of the information there doing various things.
Old Dec 10, 2008 | 11:53 AM
bigleman's Avatar
i still dont understand why that site is blocked here at work for "Violence"
Old Dec 10, 2008 | 12:15 PM
Thanks a ton guys!
