Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
c5 frc questions
Old Jan 23, 2009 | 02:41 AM
SERB Z06's Avatar
Originally Posted by Drewstein
Umm, no. Just a cam and LTs with some non run-flat tires and you'll dust a Z06 and that's not major $$$.
For that price you could have just had a Z06 in the first place and had a better car, newer, less miles, etc.
And if I cam and LT my z06 I will dust a FRC
Old Jan 23, 2009 | 05:17 AM
apexman's Avatar
Love my budget FRC.
Old Jan 23, 2009 | 07:35 AM
Chevy406's Avatar
Like others have mentioned, if you plan to upgrade the engine it makes better sense (and cents) to start off with an FRC and the base LS1. A h/c/i LS1 will make the same power as an LS6 with similar h/c/i. I spent an easy $5k purchase price less on my FRC than the bottom end Z06s. I don't road race mine, so the suspension wasn't a deciding factor for me. Another point is that the C5's resale value is sliding pretty badly - especially for the higher priced Z06s. But in the end, buy what you can easily afford and you will be able to enjoy it longer.
Old Jan 23, 2009 | 04:37 PM
Drewstein's Avatar
Sorry but that's $3K in mods when Z's are much more than $3K from FRCs if they're in similar condition.
The rule is, if you're going to mod it, don't buy the Z. There's no way a Z with equal money could touch my FRC. I knew this going in and chose to spend wisely.
Old Jan 23, 2009 | 09:02 PM
99FRCTorchRed's Avatar
Originally Posted by apexman
Love my budget FRC.
Me to........Last summer a blue 02 Z06 pulled next to me and ask what kind of vette it was I said a FRC.........he looked puzzled.......... Than he got on it ......by the time I shifted out of 2nd gear I had 2 cars on him........when I slow to make a left turn he did not even look at me..... I quess know he knows what a FRC is
Old Jan 27, 2009 | 10:32 PM
thewhiteknight's Avatar
Default ...
so would you guys say this would make a reliable daily?? this is one of my main concerns... im not real familiar with the common problems with these cars
Old Jan 27, 2009 | 10:36 PM
BlownVette 2001's Avatar
They are relibale as long as you don't over-do the mods and take care of the car with general care and maintenance like any other car.
Lots of guys with 100 k miles on them.
Old Jan 28, 2009 | 09:00 PM
ROJO99's Avatar
If you are going to Mod I would opt for the FRC. Parts are getting cheaper by the day in today's economy and a lot of used parts are available also.
If budget is an issue, I am surprised that it has not been mentioned that a FRC will likely cost less in insurance. You will have the same basics as the Z.
Old Jan 29, 2009 | 04:38 PM
01sscam's Avatar
Man-Crush Warning
My intake exhaust FRC runs faster at the track than stock Z06's in my area. If you plan on modding the car definitely get the FRC, if you want something to keep stock and drive rarely then get a Z06.
Old Jan 29, 2009 | 06:25 PM
SSNISTR's Avatar
You must have a strong FRC then or alot of bad ZO6 drivers.
All the FRC's I know run stock 13.0's and all the ZO6's I know, stock run very low 12's and one buddy runs 11.90's all stock. So if your FRC with just and intake and exhaust is running low, low 12's I'm impressed....that's like a second off stock.
Old Feb 2, 2009 | 04:58 AM
rixsgto's Avatar
what about a regular non-frc c5? would they be cheaper? im looking into getting one myself
Old Feb 2, 2009 | 07:46 AM
  #32
SSNISTR's Avatar
Yes, usually they are cheaper. Usually goes from lowest to highest. Coupe/'vert/FRC/ZO6.
Old Feb 2, 2009 | 07:51 AM
  #33
rixsgto's Avatar
cool thanks, i guess the coupe will be the one for me
Old Feb 3, 2009 | 09:40 PM
  #34
Coupe...........
Old Feb 4, 2009 | 06:14 AM
  #35
rixsgto's Avatar
Originally Posted by 99FRCTorchRed
Coupe...........
sorry, i meant Base model.
Old Feb 4, 2009 | 01:00 PM
  #36
M-Ten's Avatar
Isn't the coupe the base model?
Old Feb 4, 2009 | 06:32 PM
  #37
SSNISTR's Avatar
Basically, yes.
Old Feb 6, 2009 | 10:07 PM
  #38
BigBirdc5's Avatar
Originally Posted by BlownVette 2001
The FRC's didn't have any ring problems. That problem occurred in 2001 models, so you don't have to worry about that issue.
The biggest issue is check for water leaks. FRC / Hardtop's some times develop water leaks around the windows or the rear tub area.
Throw a lot of water down on it and look for signs of leakage behind the seats and the headliner.
had the same problem with my car. but it leaked around the trunk seal. other than that no problems with my car. well the only thing i had a problem was my transmission but thank god it was covered by the warranty.
Old Feb 7, 2009 | 07:08 AM
  #39
dawiz's Avatar
i always get a kick out of the zo6/frc pissing match. get the frc youll be happy to save the money and end up with the faster car once you spend the savings on mods!
Old Feb 7, 2009 | 07:58 PM
  #40
01sscam's Avatar
Man-Crush Warning
I agree.
