Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Help!! Locked steering wheel on C5
Old Oct 5, 2003 | 06:18 PM
getZupjo's Avatar
Default Help!! Locked steering wheel on C5
I just bought this 01 c5 & the steering collum has locked down on me. Live in small town, chevy mech has never heard of it. Only have appx 2 vette's in town, counting mine. Leaving town tomorrow & don't want to leave it outside all week. Any help as to what to do??? Thanks in advance
Old Oct 5, 2003 | 06:41 PM
wicked 98z's Avatar
Default Re: Help!! Locked steering wheel on C5
YOu can buy a bybass kit for the steering lock. Do a search on the corvette forum. THere are alot of post on how to unlock it.
ALbert
Old Oct 5, 2003 | 07:08 PM
McRat's Avatar
I believe there is a recall in effect. If the Chevy dealer hasn't heard of it, they suck.
Old Oct 5, 2003 | 07:10 PM
McRat's Avatar
PS - With a floor jack, you can move a car. It takes awhile, but it's easy.
Old Oct 5, 2003 | 10:06 PM
getZupjo's Avatar
Thanks everyone for your help! Finally got it, the guys on vette forum told me what fuse to pull & it worked. Just in case anyone else has it happen to them it is fuse #25 in the inside fuse box. Thanks again, got her in the garage.
Old Oct 5, 2003 | 11:07 PM
Cali Guy n TX's Avatar
The fuse pull will only work in certain situations. Mine locked twice, and none of the simple fixes worked. So after the 2nd time and several phone calls to GM customer service, they fixed it under the recall campaign. BEWARE! It is a near guarantee that it will lock again, so either get the Column lock by-pass from Corvettes of Houston, or have it serviced under the recall campaign ASAP.
Old Oct 6, 2003 | 03:00 AM
jmX's Avatar
jmX
I have a bypass you can buy from here for less than half price of Corvettes of Houston. It'll make sure this never happens again.
http://www.ls1howto.com/?category=10
Old Oct 6, 2003 | 12:50 PM
Sorry jmX i forgot about you too. My bad!
Old Oct 6, 2003 | 12:52 PM
Dean-o's Avatar
I have an 03, do I need to worry about this, or is it only an issue with the earlier models?
Thanks,
Dean
Old Oct 6, 2003 | 02:28 PM
jmX's Avatar
jmX
All year C5's with 6 speed transmissions can have the issue, and pre 2001 A4's can have the issue. There is a gm recall, but the recall isn't a 100% fix either (unless you have an A4, then the recall will totally remove the column lock). Its all about playing your odds.
Some 2003's have already had their column lock up from what I've seen.
Old Oct 7, 2003 | 09:53 AM
MarkP's Avatar
I believe that there is a recall notice or service bulletin on this. Check here:
http://corvetteactioncenter.com/kb/c...y.php?catId=77
Old Oct 7, 2003 | 09:31 PM
Dean-o's Avatar
Well I have a 2003 auto and the ignition is on the dash. Is the ignition on the steering column on other models? Perhaps that has nothing to do with the lock itself being located on the steering column?
Old Oct 8, 2003 | 09:32 AM
jmX's Avatar
jmX
All C5's have the key in the dash. No A4's after 2001 have column locks.
