Thinking of buying C6 Z06...Have questions
Racer
Ive had the Kooks 1 7/8 LTs on my Fbody in my sig for bout 5 years and they dont leak at all
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
The stock rear end can handle a lot if you take care of it.
Eliminate wheel hop by installing QA1 shocks.
Put the hardened half shafts in and she will handle almost anything you through at her.
If you don't dump the clutch, and launch around 2500 rpm you won't glaze it and she will last a long time. Just use it till it breaks then worry about replacing it.
Not sure what you looking to run. A guy on the vette forums runs 10.8 stock on DR's.
Saw one on pinks running a 150 shot, tune and DR's running 9.8.
Like others have said you can spray the LS7, just make sure who ever does your tune has tuned LS7's before. Lot of people have gone boom by not using the right guy.
There is tons of info on this stuff on z06vette.com and corvetteforums.com and corvette-forums.com
Aluminum frame custom made by Dana Technologies
505 horsepower @ 6200 rpm
475 lb.-ft. of torque @ 4800 rpm
7000-rpm redline
Unique engine block with larger 104.8-mm (4.125-inch) bores and pressed-in cylinder liners
Forged steel crankshaft with 101.6-mm (4-inch) stroke
Titanium connecting rods
Cast aluminum flat-top pistons
Racing-derived CNC-ported aluminum cylinder heads with titanium intake valves and sodium-filled exhaust valves
Dry-sump oiling system
11.0:1 compression ratio
Camshaft with 15-mm (.591-inch) lift
Hydroformed exhaust headers with unique "quad flow" collector flanges.
Magesium engine cradle
Magnesium roof
Near 50/50 weight distribution
Larger wheels/tires
6 piston front calipers, 4 piston rear
Upgraded suspension
Factory wide-body to accomodate the larger wheels/tires
Carbon fiber front fendors to help with the weight distribution
Battery relocation to the rear
All that, and you still get the 5 year, 100,000 mile powertrain warranty. Do all that to your C6 and then let me know where you end up financially (and with no warranty
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
You really don't know much about them, do you:
7000-rpm redline
Magnesium roof
Larger wheels/tires
Upgraded suspension
7000-rpm redline
Magnesium roof
Larger wheels/tires
Upgraded suspension
EXACTLY!
BUT, I am looked at modded Z51's.
Cheaper, still handle great, faster than a stock Z06 (can be)
I would love to have a Z, but for the price increase, AND since my car will be a street car, and not on a road course...Z51 will keep me happy
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
But to say the Z06 is nothing special for the price is just plain naive. Z06 is a supercar, and the best bang for the buck in supercars the world over. You can add power to a C6 coupe and even do a wide body conversion, but it will never be a Z06. Mod for mod, a Z06 would destroy the C6 coupe in every category. Did you see the video of the supercharged Z06 A4 conversion that was running 8s in the 1/4 mile?
Stock block, stock crank, stock ported heads, stock intake... Try this with your stock block, stock crank C6 coupe.
http://www.youtube.com/watch?v=gL2su8eMEIc
![Icon Eek](https://ls1tech.com/forums/images/smilies2/icon_eek.gif)
There's a guy running consistent 10.8s in a 100% stock Z06 on drag radials, too.
#32
http://www.tick-performance.com/tickshift/
for all you guys with shifting problems, check out the tick master.... very helpful guys also...
#33
7000-rpm redline
Magnesium roof
Larger wheels/tires
Upgraded suspension
7000-rpm redline
Magnesium roof
Larger wheels/tires
Upgraded suspension
#34
I don't see **** on the URL you provided. If this is a drill out mod that will stop the pedal from sticking to the floor, I'M IN!
#35
7000-rpm redline
Magnesium roof
Larger wheels/tires
Upgraded suspension
7000-rpm redline
Magnesium roof
Larger wheels/tires
Upgraded suspension
#36
I would have prefered an 06 Z when I was shopping.
Anyone remember the hype when the 06 Z06 came out?
Since the 05 did not have a Z, the 06Z was getting a premium so they cost around $100k back then. Of course they have come down a bit. and a used '06 if not dogged is quite a "good buy".
But I bought all I could afford at the time which was an 06 Z51. And I didnt know it then but there was a mod and power going around and I caught it.
#38
#39
I have owned dozens of cars in my day, mostly F'bodys and a couple C5s and now own an 07 Z06. I've owned the car roughly a year now and I am STILL amazed at how awesome this car is...
There are very significant changes between the reg C6 and the Z06, most of them are not easily seen (as mentioned above). This is just truely and awesome car and has come down in value significantly! I saw an 06Z w/ 30k miles sell the other day for under $40K! What an absolute steal!
UL Lose, find yourself a Z06, you'll be very glad you did!
