Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Running Rear o2s in the Front bung
Old Mar 6, 2009 | 09:40 AM
ChevyWeatherman's Avatar
master of the "jack"stand
Originally Posted by ls1290
WTF?!?!? First I am not sure that is even possible. Second, why in the hell would you want to do that. In closed loop mode, the LTFT are very important in determining the amount of fuel to be delivered. Has your tuner worked on a EFI car before.
I am friends with one of the owners of HP Tuners. He had LTFT's turned off in my car when I bought it from him, so I'll take a guess that it isn't that big of an issue.
Old Mar 19, 2009 | 01:02 PM
LS1C5Vette's Avatar
Originally Posted by SBcamaro
so are you runing cats
No cats
Originally Posted by 06X6spdGTO
nope, no cats. ls1c5vette with the plugs being different how did you connect them??
Bought adapters for $50 from I forget where
Old Mar 24, 2009 | 06:50 PM
VeroWing's Avatar
I'm new here, and don't want to be a smart guy, but, from everything that I've ever been told regarding C5 Corvettes is, that the rear o2 sensors have a hotter heater than the fronts. That is why many people recommend placing rear o2s in front when adding headers. Again, I'm no authority, but I have been advised of this by a few well learned C5 people. Mike
Old Mar 24, 2009 | 08:38 PM
VeroWing's Avatar
Just found this on another thread info from a Bosch tech:
'He did shed some light on some of the issues at hand. First off, he said that the heaters in the front sensor are the same as the heaters in the Corvette rear. However, there is a difference in the baffling of the sensors and that the baffling does effect the temp they run at, and due to this difference he thought that the rear Corvette sensors, when used as fronts, would be at an advantage over the fronts.'
So I stand corrected, sensors appear to be the same, with different baffling.
