Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Running Rear o2s in the Front bung
Old Mar 3, 2009 | 01:04 AM
06X6spdGTO's Avatar
Default Running Rear o2s in the Front bung
My tuner has informed me that my front o2 sensors cant perform up to par. he said i need to look at running my REAR o2 sensors in the front locations due to the rear sensor being able to run hotter. has anyone done this???
FWIW i have Kooks 1 7/8LTs.
Old Mar 3, 2009 | 02:42 PM
~JOSHUA's Avatar
Actually, they are the same sensor.
The only difference is the longer cord/cable on the rears.
You can run rears on the front, but it will have no bearing on heat... same thing just with extra cord left over.
Old Mar 3, 2009 | 03:08 PM
06X6spdGTO's Avatar
so the plug-ins on the o2s are exactly the same???
Old Mar 3, 2009 | 03:24 PM
gold98Z28's Avatar
yes the plugs are exactly the same, i know some cars call for the same sensor in all four and some call for a differant one, some may have a better heater than others, but they all work.
Old Mar 3, 2009 | 03:36 PM
06X6spdGTO's Avatar
good becuz i currently have the LG wiring harness for extending the front wires, now i just need a better (Hotter) sensor since the fronts a moved farther from the Exhaust port.
Old Mar 3, 2009 | 07:59 PM
FourG63 97GST's Avatar
I run rear O2 sensors in my front bungs on my longtubes, the connectors are different, but if you have the LG adapters you're ok
Old Mar 3, 2009 | 08:02 PM
06X6spdGTO's Avatar
ok so the connectors from front to rear are different! Thanks
Old Mar 3, 2009 | 11:55 PM
gold98Z28's Avatar
hum... maybe the vettes have differant plugs on them..... what year is the car? i know the fbodys all four are exactly the same. are the ls1 vette's differant front to back too, or just later ones? i stand corrrected
Old Mar 4, 2009 | 12:21 PM
06X6spdGTO's Avatar
2001 ls6 z06
Old Mar 4, 2009 | 03:42 PM
SBcamaro's Avatar
the plugs are differant in frount & rears the 02 sensors are the same
Old Mar 4, 2009 | 03:47 PM
Rossi396's Avatar
Are you getting codes after the header install?
Old Mar 4, 2009 | 04:07 PM
06X6spdGTO's Avatar
no im not getting codes my tuner just had to shut off my LTFT for both banks due to trouble tuning with the o2s not running hot enough
Old Mar 4, 2009 | 07:25 PM
LS1C5Vette's Avatar
Yea the plus are different, I run my rears in the front
Old Mar 4, 2009 | 08:15 PM
pewter2165's Avatar
So is there a hotter o2 sensor?
Old Mar 4, 2009 | 08:41 PM
SBcamaro's Avatar
Default 02
so are you runing cats
Old Mar 5, 2009 | 08:18 AM
06X6spdGTO's Avatar
nope, no cats. ls1c5vette with the plugs being different how did you connect them??
Old Mar 5, 2009 | 08:43 AM
ls1290's Avatar
Dumb Ass Vette Moderator
WTF?!?!? First I am not sure that is even possible. Second, why in the hell would you want to do that. In closed loop mode, the LTFT are very important in determining the amount of fuel to be delivered. Has your tuner worked on a EFI car before.
Old Mar 5, 2009 | 10:02 AM
gold98Z28's Avatar
um... not only very possible but very common. short trims are the norm for tuning. much faster and better than waisting a tank of gas waiting for long trims to settle in and average out. if the tune is inline the long trims are not needed. most turn them back on after tuning but some dont, ive had mine turned off for over a year. they are only used as a stored look up table, short trims are your instant fueling.
Old Mar 5, 2009 | 03:00 PM
06X6spdGTO's Avatar
My tuner has been tuning cars for about 8yrs now. Its Dyno Dan owner of Dynosport in Lincoln.
Old Mar 5, 2009 | 03:02 PM
06X6spdGTO's Avatar
http://www.dynosport.com/
Heres his website.
