Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Will the diff break?
Old Mar 4, 2009 | 08:30 AM
pontiac's Avatar
Default Will the diff break?
Ok car makes just under 400 rwhp, its an 06 Z51 car. On MT drag radials... how hard can I launch this thing with out breaking it? stock clutch.... and i am talking at a track where it will hook.
I come from an F-body with a 9" in it. haha 2 step set at 6000 and side stepping the clutch....I know i cant do that.
Old Mar 4, 2009 | 08:48 AM
ls1290's Avatar
Dumb Ass Vette Moderator
DRs are pretty hard on the drive line due to the fact they have very little sidewall give and the drive line has to absorb the energy of the launch. At 400 rwhp things should be good. 500+ rwhp is a completely different story with DRs.
Old Mar 4, 2009 | 08:08 PM
highpockets's Avatar
one good hook and you will be towing it home.It will snap the long side OP shaft.Easier to do it now,then play.
Old Mar 4, 2009 | 08:20 PM
Cole Train's Avatar
i'm hoping my Vette will be able to handle the Nitto 555R's going on my car this spring Only upgrades gonna be done to driveline is the clutch
Old Mar 4, 2009 | 08:31 PM
golfinz's Avatar
Just dont dump the clutch and youll be fine...now the half shafts are a different story
Old Mar 4, 2009 | 08:38 PM
VGLNTE1's Avatar
its going to be fine...just get out fast if you wheel hop. But, if you are going to dump the clutch at 6k with DR's, you are just going to spin. Might as well get some real tires for the track if you want to leave hard
Old Mar 4, 2009 | 10:08 PM
Cole Train's Avatar
yeah i don't plan to do any clutch dumps. I did think about putting a DTE rear brace and will be doing Bilstein Sports
Old Mar 5, 2009 | 02:34 AM
sultan(ZR-1)KSA's Avatar
how much tourqe do u have that will determan if you brake it or not not haw much horse pwer , and please do not side stip the clutch
Old Mar 5, 2009 | 11:23 AM
pontiac's Avatar
why not? I am not going to burn my clutch up...i would rath just 2K dump it and bog and have a 1.9-2.0 60 then burn the clutch
Old Mar 5, 2009 | 11:26 AM
VGLNTE1's Avatar
slip it. Try to have it fully engaged by 10 feet out. Get it down and you can see 1.7-1.8 60 times
Old Mar 6, 2009 | 12:48 AM
pontiac's Avatar
but that 3000 rmp slip on tires....make me think i will be replacing my clutch SOON.
Thoughts?
Old Mar 6, 2009 | 03:20 AM
I agree 100%
Old Mar 6, 2009 | 06:39 AM
Dragman's Avatar
Dont waste ur money go get some M/T DRs instead. Any power with Nitto;s they suck! Last set of M/T DRs 295x45x17s I got 5200 miles and 39 passes at track and was only down to wear bars on tires.
Old Mar 6, 2009 | 07:05 AM
UL LOSE's Avatar
Racer
I think you should go ahead and buy a DTE Brace and Hardened Output Shaft & then hit the track.
Old Mar 7, 2009 | 02:58 PM
VGLNTE1's Avatar
Thoughts?
i would start at 4500 or so, and slip it. Yes, it wears the clutch, but you ARE racing just get it so your tires dont spin, but you are accelerating hard. Its def not easy. Takes lots of practice
if you want results, you need to beat it.
Old Mar 8, 2009 | 09:26 AM
Cole Train's Avatar
^ The only problem with that is if he DD's it too and needs it to be somewhat reliable. I know i have to replace the clutch this spring and hope my new one lasts a while. I don't drag race much though so once or twice of slipping it and i should be fine. I was hoping Nitto 555R's would be ok but i guess not
