Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
HELP!!!!!!!!! Spark Plugs
Old Mar 16, 2009 | 07:31 PM
DirtyBird310's Avatar
Default HELP!!!!!!!!! Spark Plugs
Was doing the first tune up on my gf's vette and when i was taking out the plug in cylinder 3 it wouldnt budge. so i took a breaker bar to break it lose. well after breaking it lose the plugs would spin but now it doesnt want to come out or screw back in has anyone had this happen to them and did you fix it i am in a bad way right now
Old Mar 16, 2009 | 07:47 PM
JayplaySS's Avatar
Moderator
Never heard of that
Old Mar 16, 2009 | 07:54 PM
MetallicaMatt's Avatar
did you strip the threads out?
Old Mar 16, 2009 | 08:41 PM
I think that is it i just need to get it out now
Old Mar 16, 2009 | 11:19 PM
allngn_c5's Avatar
You broke off the plug in the cylinder ?
If so there is a very informative thread up, if I find the link I'll post it here for you.
Good luck, and what did the G/F say when you told her ?
Old Mar 16, 2009 | 11:25 PM
sanya_kim's Avatar
****, that sucks man.
have you tried just pulling it out?
I don't know if easyout will work on sprak plugs
Old Mar 16, 2009 | 11:45 PM
Gf was working on it as well didnt break the plug though it is just stuck in the head it spins and wiggles but it doesnt want to come out, if you can find that link that would help me out alot if not i will be taking the head off this weekend
Old Mar 17, 2009 | 12:27 AM
allngn_c5's Avatar
I looked, but I don't have my contacts in. LOL. Anyways I'll look again tomorrow, but the gist of the thread is that the OP actually broke the plug off in the cylinder and the only way to fix it was to remove the head.
Old Mar 17, 2009 | 12:31 AM
allngn_c5's Avatar
Found it
https://ls1tech.com/forums/generatio...well-sort.html
Hope it helps
Old Mar 17, 2009 | 06:02 AM
could it be that the "nut" on the spark plug broke and then the thread part is remaining?
sounds like a PITA either way
Old Mar 17, 2009 | 04:37 PM
JayplaySS's Avatar
Moderator
Originally Posted by allngn_c5
Shet, I have never seen that before.
I would figure out a way to get it out without pulling the head. Pull the manifold, let it sit overnight with penetraing oil and pray like hell. I would refuse to remove the head....well until I actaully had to.
Old Mar 26, 2009 | 09:31 AM
FrkEBz06's Avatar
What year is the car and how many miles? Cause im guessin someone changed the plugs without antiseeze or anything smeared on the threads of the plug allowing it to corrode probly cause they let moistue or get to it. Or they couldve torqued it way to much to where they couldve cross threaded them, with or without something to prevent seizing. All i got to say is atleast the vettes heads are one the easiest things to remove on em. lol
Old Mar 26, 2009 | 01:00 PM
Well I took off the head and I ended up breaking the base of the plug due to no antiseize on the plug the thing look rusted took a all a hammer and a easy out to get the job done and thread was saved anyway fished the car last night going to fill the coolant and ps fluid I see what happens next after I turn it over
Old Mar 26, 2009 | 01:37 PM
FrkEBz06's Avatar
I WIN! but man thats total bs that you had to do that. If people would go that extra limit and spend a lil more time to do things right, big problems wouldnt occur like that. People are to damn lazy and ignorant to realize the small simple things count in the long run.
