What does your oil Temp run.
What kind of oil are you running ?? You might need a little thicker oil.
I have a 402 stroker and run 15w50 mobil 1 as directed by LG Motorsports, and I also have a built in oil cooler. My oil temps barely see 200 degrees unless I am just sitting for a very long time after getting on it a bit.
Seeing that you are in Houston and it gets hot you should be running at least 10w30 mobil 1 or 10w40 to give more protection from the heat. Just trying to help, maybe someone else will chime in and add there 2 cents.
To repeat : I say 220 is normal.
Ambient temp was 97*, speed 77 mph. Oil 237, coolant 201 and tranny fluid 192.
I'd suggest you run 10w30 in that kind of heat. The 5w30 must be thin as water. Anyways I run 15w50 per LGM's orders on the new stroker.
I would look to see what your fans are set to come on at. My oil temps even with a built in oil cooler were in the upper 220's briefly when we were getting on it for the camera. If you don't have an oil cooler, then I'd suggest you get one. The meziere ewp will be fine. Just verify both your cooling fans are coming on and at what temp. Best of luck, and btw have you gotten her on the dyno or still breaking in. PM me your setup please. Very interested.
Thanks bro, it was a solid 100 when I was seeing those temps and of course I was up and down shifting the car every 5-10 seconds to vary the RPM during break in. I am running Joe Gibbs break in oil. I think it is 20-50? My setup is below
Forged 402 (-10cc coated pistons) rings set up for 300 shot
PREC 2.5 heads milled to 62cc
Comp XER 244/248 .612/ .615 114+4
Mezeire EWP
HS 1.7 NA Rockers
Vararam
Kooks 1 3/4
3" X and connecting pipes
DMH 3" LP electric cutouts
ZO6 Ti exh
Ported FAST 90/ non ported LS2 90mm TB
High flow airbridge
Cometic .040 HG
I think that is all that would effect power. I have 300 more break in miles before I can dyno it.
I think the SCR is 12:1
