Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Weird Problem.
Old May 16, 2009 | 04:44 AM
CobraB8_ZO6's Avatar
Default Weird Problem.
Ok so tonight I was driving my Vette and left the a stop light and did a WOT pull through 4th. When I pulled 4th my Check gauges light came on the temp went past the red oil pressure went to the bottom it said I had no fuel and it said reduced engine power on the read out above the steering column. Plus the passenger side window wouldnt roll up. So my first instinct seeing no oil pressure and a sky high temp was shut the car off so I did and let it coast for about a 1/2 mile. I cranked it back up and everything went back to normal except the passenger side window still wouldnt roll up. Then about 2 miles later it done the same thing so I cut it off again and keep repeating the process all the way home. I get home and my passenger opens the door and the window starts working again. So after a couple hours I get in it to go home and everything seems fine. No problems what so ever. In the morning Im gonna get up and check all of the obvious (fuses, relays, wires, connections, etc.) If anyone has any info or any experiences such as this let me know. Any help is greatly appreciated!!
Old May 17, 2009 | 02:59 AM
BUMP.....anybody?
