3mph and car shuts off?
installed teh new clutch and went to drive the car. first thing i noticed is steering column lock service came up. now the car starts up perfect and revs if sitting still. as soon as go into gear and let the clutch out it stalls.
this is a 2001 convt vette. as of right now it is completely stock. this has me a stumped a little bit. the customer said he had teh steering clolumn lock serviced at dealer last summer. but car has been sitting for 8 months due to clutch.
things tried so far.
-reset teh BCM
-replaced battery with known good one
-tried disconnecting the speedo to see if could be driven
-pulled fuse 23 and 25 as some people have stated to reset everything
thanks in advance
Try doing a passlock relearn. If you have TIS2000 you can do this in 12 minutes. IF not, anyone can do it from home by doing a thirty minute relearn. key on, engine off, for ten minutes or until theft light goes out,...continue 2 more times(3 total hence 30minute relearn,....is actually more like 33-35minutes total).
But first things first,any codes in any module that matters?
thanks keep the info coming
Pitt
put one of these on and be done with it...
it also helps to change the mph when doing the tune also....
looks like ordering the kit today. may order extra for the other customers too if this is bound to happen regardless
not for what i am understanding if the dealer did the steering column service the box from corvette of houston will not work. correct if i am wrong?
on later model thought it was a pcm reflash? if so how is it reversed so that i can use the box?
i told em. Problem i find with most dealers is that they think im the run of the mill vettes owners round here. lol 1) Buy a new battery
2) Use hptuners and change the stering lock cutoff (2mph) to 255mph.) This way even if the code ever pops up, the car never turns off.
I never went thru the dealer, but I did buy the bypass from Thunder Racing. Seems to work just fine.
