Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Can't get the engine back in!! help
Old Aug 9, 2009 | 10:27 PM
BlownVette 2001's Avatar
Originally Posted by Notmyvette
Nope didnt finish it, its really pissin me off and it takes alot to get me aggravated. I jacked up the body of the car in attempt to let the cradle drop, no gap unless I stuck something in there and pryed it down, took off the shock, no change....started to take out the 4 upper control arm bolts so the cradle can come down....assuming thats the only thing thats holding it up against the body. Is the a arm going to shoot down and be a biotch to get bolted back up when I take out the top control arm bolts?? I have a jack under it but if I jack it up all it does is raise the whole car up so I have a feeling I wont be able to jack it up in place?
Use a jack and jack up the arms so that you can remove the lower "A" arm thru bolts in the cradle. Be carefull not to get yourself pinched in because the front springs are under 700 pounds of pressure.
Once you get the lower "A" arms off, the cradle will drop some but be held up if the steering rod is still attached.
Old Aug 10, 2009 | 01:33 AM
Notmyvette's Avatar
Yea the steering shaft is out and the steering rack is unbolted also
When I tried jacking up the a arm it just raised the car instead of the a arm is if the spring is too tight or the car isnt heavy enough. If so that means when I finally release all that spring tension the a arms either going to shoot down or the cars going to jump up. Will unbolting the lower control arms prevent this? only cuz I started unbolting the top of the a arm already since the bolts are easier to get at
Old Aug 10, 2009 | 07:53 AM
Just set a jack up under the lower "A" arms, remove the two lower bolts (21mm). Slide out the bolts and then use the jack to release the pressure. which should allow you to drop the cradle.
Old Aug 10, 2009 | 11:01 AM
highpockets's Avatar
You could also just remove the nut from the lower ball joint,leaving the arms attached at the cradle and not disturbing the alignment.unbolt the two rack to cradle bolts,unclip the brake lines and abs wire(leave connected) pop the arms out of the spindle and lower the whole assy as needed.You WILL need to put some pressure on the arms to get them back in the spindles when done,we usually end up with just enough on the outer end of the lower arm to barely raise that corner of the car off the stand.Its usually a little easier than trying to line up the camber/caster bolts on the other end under tension.
Old Aug 10, 2009 | 03:05 PM
viper9403's Avatar
I put a jack under the front k-member and dropped it down, with the front bumper removed it goes right in.
Old Aug 11, 2009 | 08:07 PM
Notmyvette's Avatar
Yep, did that, seperated it from the lower balljoint and got the cradled dropped, the kid that owns got the motor mated to the shaft, im headed over there now to get some more done
Old Aug 12, 2009 | 11:04 PM
Notmyvette's Avatar
Well, the engine is IN and bolted in with the cradle back up and tight. On the last control arm the balljoint is through and nut is on, but I cant get it tight since the bj spins with the nut....I have the jack under it jacked all the way up till it starts lifting the car and gave some love taps to the arm down to help it seat in the taper but still spins.....any other ideas? It worked for the other side but no dice here
Old Aug 12, 2009 | 11:21 PM
You need the correct size hex key to stop it from spinning why you tighten it. I think they are 6mm.
Old Aug 13, 2009 | 07:07 AM
Notmyvette's Avatar
o yea thats right, forgot it had a internal hex. It's a little rusty I think such a small size like that might slip out easy but I'lll see what happens
