Can't get the engine back in!! help
I backed all 4 k member nuts down like 6 threads, enough so the threads are still all in the nuts but not so the member will drop all the way down and hopefully it will be enough clearance for the motor to drop for the input shaft to slide in...
Does everybody put the chassis on jackstands and then lower the k member down with a jack or use a lift to lift the car off the engine?
When I do clutch swaps, I end up taking the rear cradle bolts out obviously,and I support the front cradle with pole jacks. Then I remove the rear FRONT cradle bolts, and loosen the front two cradle bolts to the point where they become even with the studs. Make sure you are useing all HAND TOOLS when working with the cradle bolts, no air tools.
Should give you a little extra room. Also, during clutch installs, we leave the pressure plate loose enough to allow some play, then once eveything is tight, we go through the bellhousing site plate, and tighten each one. Helps with alighnemt alot. Getting the bellhousing can sometimes be tricky, as the dowl pins down want to line up sometime. It's probably not 100% straight. Ensure that the torque tube is,...line it up, try and start one bolt,..slowy thread it in, start another,...turn it,...another,...never tightening one all the way down, cause if it isn't lined up, you could crack the housing or the tube.
Haste makes waste....or some **** like that. Take your time, be safe.
Well I used my snap on 1/2 cordless impact for the 4 k member nuts then I realized how loonnggg they are and plan on tightening them by hand so they dont snap.
About the oil pan it's not even my car, I'm doing all this for a friend for some $$$ and motors already almost in and dont have time to wait for another oil pan but I prob would have had it running by now if it did have a wingless pan on it.
Well Im gonna head over soon and try and drop the k member or cradle whatever the correct name is and see what happens....
Anybody know where I can get header bolts locally? I dont have time to wait for shipping
After I loosened the first nut it was wobbling around in the hole and was wondering what was holding it and found the top of the bolt on the frame rail with a tab thats riveted to the frame to hold the head from turning...Even it did break should be no biggie to hold the top or to put in a new one.That was on the passeneger side anyway, I think I seen the same thing on the driver side
YOu can find bolts that will work at the hardware store but, they may not thread in as easily, as the heads on the factory bolts are kinda tapered. Be careful you don't cross thread the aftermarket bolts,..as it is very easy to make a mistake on the aluminum heads
