base ls2 C6 specs?
don't think im putting the C5 Z06 down, i love them, i had an 01 Z to me it did seem to handle better stock for stock on the back roads and was more fun on the back roads since it was a manual.
dicky
dicky
dicky
Next, the C5Zs may be "rated" at 405BHP, but they're obviously under rated since they dyno between 360-370RWHP consistently. Do the math: 360 x 0.85 = ~423HP. These are consistent numbers so don't tell me about what a GM fact sheet says. Real world numbers are better for bench racing.
Um... An LS6 is not a mildly tuned LS1. They're totally different in stock form. Cam, valves, heads, intake, tune, injectors, etc. The LS6 Vettes make 60HP more to the ground than LS1 Vettes. A fully N/A LS6 can make over 500RWHP with supporting cam, heads, manifold, and exhaust. I've seen it although it's not very streetable. Sorry to say, the LS2 isn't that much better. The displacement isn't that much more over a 5.7L. Look at the LS7. You really need to go to a 402 or better when you want that kind of power to the ground and still be perfectly streetable. (Especially with a manual).
You should take a look at the fast list for stock C5Zs. (http://forums.corvetteforum.com/1557690447-post2.html)
There are C5Zs in the 11s completely stock. Power to weight ratio plus the MN12 transmission gives the C5Z a HUGE advantage over the LS2 C6 Coupes. The C5Zs are geared to the equivalent of 3.90 gears in the diff.
but look at dicky98z he has full bolt ons and still didnt make more than my dads ls6 z06 with just intake and tune which weighed 3080lbs.
get the ls6 z06 imo
OK, you ran 12.58 @ 112MPH. That sounds like you got a great launch. The C5Zs are rated at 12.7 @ 117MPH. You're going to argue that the LS2 Vettes are faster?! Again, look at the fast list for bone stock C5Zs. (http://forums.corvetteforum.com/1557690447-post2.html) Notice there are plenty of them running much faster than your LS2.
dicky
I'm going to be at LA Invasion so I'll post up my times. I've never either of my Z06s on the track so this will be my first runs. I'll be at Irwindale tomorrow to practice launching.
I'm not the best behind the wheel, but I did manage to get better times with my dad's manual Solstice GXP than GM stated and that was at high elevation. I'm hoping to run 12.5 or better.
Showroom Stock LS2 (2005 -2007)
12.21 @ 115.45 - LS1LT1 - 06 A6 - (1282)
12.23 @ 115.58 - 06C6FVR - 06 M6 Z51 - (337)
12.31 @ 114.82 - CYA Vett - 05 M6 F55 - (679)
12.38 @ 115.86 - Proney - 07 M6 - (3521)
12.42 @ 113.90 - DrRichie - 05 M6 Z51
12.49 @ 114.90 - Jschindler - 05 M6 Z51
12.53 @ 113.00 - Wicked07C6 - 07 M6 Z51 - (918)
12.54 @ 113.59 - Tony 63 Vette - 06 A6 - (1514)
12.54 @ 113.74 - Tony96LT4 - 06 A6 Z51 - (1153)
12.56 @ 113.39 - Red Sleeper - 06 A6
12.56 @ 112.00 - Orange C6 - 05 A4 Z51 - (60)
12.63 @ 114.88 - Prankster - 06 M6 - (1625)
12.64 @ 108.69 - DMcRacer - 07 A6 Z51 - (4223)
12.65 @ 111.65 - Zippin Zee - 05 M6 Z51 - (51)
12.66 @ 113.03 - Mdrrandall - 07 M6 Z51 - (1679)
12.69 @ 112.32 - Silverlx - 06 A6 - (876)
12.70 @ 112.43 - Jelsis - 06 A6 Z51 - (456)
12.70 @ 113.00 - Blackmajik - 07 A6 - (1631)
12.71 @ 111.30 - Flyin05 - 05 M6 Z51
12.71 @ 111.00 - Demented - 05 A4 Z51
12.74 @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.75 @ 109.25 - Ponchorello - 05 A4 3.15 - (994)
12.76 @ 112.57 - C5Pilot - 07 A6 Z51 - (907)
12.79 @ 112.17 - Jchazr - 05 M6 Z51 - (451)
12.80 @ 111.00 - SheDevilC6 - 07 A6 Z51 - (1672)
12.81 @ 112.83 - Vette-oholic - 05 M6 Z51 - (498)
12.81 @ 110.95 - SkyKing - 07 A6 F55 - (2488)
12.85 @ 114.53 - Mr Z51 - 06 M6 Z51
12.93 @ 111.40 - DiggyMoe - 07 M6 - (969)
12.97 @ 108.00 - Ginny C6 - 05 A4 F55 - (60)
12.98 @ 108.00 - Tampa Vet - 05 A4 3.15 - (123)
12.99 @ 111.70 - C64ME - 05 M6 Z51 - (333)
13.04 @ 109.15 - TMyers - 06 A6 - (532)
13.05 @ 113.31 - RDunn - 06 M6 - (986)
13.10 @ 108.70 - Rothchilds - 05 A4 F55 3.15 - (1087)
13.12 @ 110.40 - JDWK - 05 M6 Z51
13.25 @ 110.60 - C6 Matt - 05 M6 Z51 - (122)
13.26 @ 108.59 - Sfadchi - 06 A6 Z51 - (888)
13.26 @ 105.30 - Joeking - 05 A4 Z51 - (661)
13.30 @ 107.00 - Shurite44 - 06 A6 Z51 - (769)
13.35 @ 108.10 - Phatpharmd - 06 A6 - (595)
13.62 @ 106.18 - Rich28 - 05 A4 Z51
I didn't get to run yesterday. Friends all backed out last second. But I'm still in for LA Invasion and I may go Thursday to the 8th mile to see how I do.
The best pass for a bone stock C5 Z06 is an 11.78, over 4/10ths quicker than my C6's bone stock 12.21.
