Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Want a AGRESSIVE CAM for z06
Old Dec 20, 2003 | 07:05 PM
CraZee ZO6's Avatar
Default Want a AGRESSIVE CAM for z06
Hey guys..
I want to put a CAM in the z06. I want to keep the stock heads for now. I want something agressive, but something that can be driven daily. Im very close to vette doctors and willing to make the trip to Cartek. What do you guys recommend. Car is totally STOCK right now, only had her for 1 month. My plan is to throw on longtubes and off road x before the cam.
Also what kind of power do you think ill make? What mph traps?
Thanx let me know..
-Zee
Old Dec 21, 2003 | 07:42 AM
ESP101's Avatar
we have a good cam that will make 400 plus on a Z06 call me at 203 619 4732at eastside peformance if interested thanks guy
Old Dec 21, 2003 | 11:31 AM
FLYNLO's Avatar
You can pretty much get any cam you want from most tuners. LPE has a nice cam that may fit your desires.....228/228/.588/.588/114(it might be 224 on the duration). Fairly aggressive on the intake and duration and the 114LSA helps with driveability. In any event, the difference between insane lopey aggressive and absolute stealth/almost stock idle is 20rwhp at the most. You may be one of the types that needs every hp but you really start sacraficing when you get to the end of the spectrum for not much increase in hp.
Expect 400rwhp from mild to near 420rwhp with alot of shake rattle and roll. Your trapspeeds will be in line with the power you make. 400rwhp in a ZO6 is around 120mph(most I have seen is 122). Good luck. Call the guy at East side. Also try the guys you spoke of....Vette Doctors, Cartek. Try MTI. ANd don't forget Lou at LGM.
I have found Lou to be very helpful without trying to cram his product down your throat. It's good to talk to all these people and then you can make a decision on what you think is best for your needs. Good luck.
Old Dec 23, 2003 | 07:23 PM
Ling_650vette's Avatar
LPEs two LS1 cams on their website are 207/220 .573/.580 w/ 1.7 rockers 117.5 CL and the other is 218/229 .560/.560 w/ 1.7 rockers 113 CL. But the is a plethora of LS1 cams out there that are aggressive. Thunder Racing, MTI, LPE, ARE, LGM are all names in this game that can definatly help you out. And I dont have first hand experience w/ Lou but just knowing his name and rep, he's a stand up guy. And the people @ LPE are very curtious and answer your question(s) ASAP (that i know first hand). Been hearing a lot of people going for this new i think its G5x2 cam. Dont know the specs on it, but its supposedly pushin some pretty good #s.
Old Dec 24, 2003 | 04:59 AM
pdd's Avatar
pdd
tr230
Old Dec 24, 2003 | 02:44 PM
Roger White's Avatar
I ran 10.86 @ 123 mph in my A4 vette with stock heads and the M2 cam from MMT.
That was also in a heavy coupe, a ZO6 set-up right should fly.
Give Sean a call this is a AGRESSIVE CAM, matter oh fact he has a MR2 that might fit your needs perfect.
Old Dec 24, 2003 | 09:41 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
See the thread from Jeremy (Godspeed) on his cam only g5x3. 427 rwhp and 401 TQ on a stock headed z06.
Old Dec 25, 2003 | 09:23 AM
C5 CU's Avatar
Originally Posted by CraZee ZO6
Hey guys..
Thanx let me know..
-Zee
.....i have had several "cam only" levels in my Z06, I found tuning makes a lot of difference, small cam poor tune = bad driveability and big cam good tuning = pretty good driveability....lots of good choices, anything from a 228 up to the LGs work great in ZO6s. expect from 400 to 420rwhp w/headers and air intake. Cats or w/o cats is about a 10hp decision.
Old Dec 27, 2003 | 12:29 AM
LittleBoyBlu99's Avatar
Old Dec 28, 2003 | 06:08 PM
Drew98TA's Avatar
nice numbers on the m2 cam
Old Dec 29, 2003 | 04:56 PM
SPANKY LS1's Avatar
427/410 cam only Z06 with soundclip....
Shawn
Old Jan 9, 2004 | 02:50 PM
07BlueDevilZ06's Avatar
our cam made 432 in a cam only ls6 motor in a camaro
Old Jan 9, 2004 | 07:04 PM
BoneStock's Avatar
G5x-3 :d
