Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Holy $hit!
Old Feb 15, 2010 | 11:28 AM
BitViper's Avatar
Default Holy $hit!
Ok.. this all started Saturday whe I need to to take my 04 in for its smog check.. it passed with flying colors the snif tests.. but failed the visual because of my VARARAM intake...
I then found a OEM intake and spent the rest of my weekend end pulling out the VARARAM an swapping in the borrowed intake Thanks to Rickko.. you rock dude..
Rick posted some intresting information that got under my skin..and so I started digging!
He posted
Originally Posted by Rickko
"Again it depends upon the technician. Some are extremely ****, and some are rather loose on air filtration systems.
The DCA/BAR's ruling on them is as Follows on Page 4 of Appendix K: Under Items of Non-Concern, Cold Air / Air filtration systems that retained ALL of the factory EVAP hoses, fittings and connections, are legal.
IIRC, since the Blackwing removes the box, but allots the Air Injection system to still have access to air (via a filter placed on to that inlet line), it should indeed be an item of non-concern, thus passing the test."
So spent the rest of the weekend swapping systems ands researching documents...
I found this...
The "SMOG CHECK REFERENCE GUIDE", a Bureau of Automotive Repait booklet states in Appendix G...
In the introduction ...
Introduction
Aftermarket parts fall into four categories:
• Replacement Parts
• Consolidated Parts
• Modified Parts
• Add-on Parts
In general, Modified Parts and Add-on Parts require California Air Resources Board (CARB) (this wwe all know..)
exemption through an Executive Order (EO).
Replacement Parts and Consolidated Parts do
not require exemption. For more information, see the definitions below.
CARB Definitions of Aftermarket Parts
Replacement Part
“Replacement part” means any aftermarket part intended to replace an original equipment
emissions-related part and which is functionally identical to the original equipment part in all
respects which in any way affect emissions (including durability) or a consolidated part.
California Code of Regulations (CCR) Title 13 § 1900 (b) (20)
Replacement parts do not require a CARB exemption to be installed on vehicles in California.
Examples include replacement air filter elements, spark plugs, spark plug wires, distributor
caps, chromed valve covers, replacement EGR valves, and replacement carburetors. (Note: A
replacement EGR valve or carburetor must be specified as replacement, by the part
manufacturer, for the vehicle on which it is installed).
Consolidated Part
“Consolidated part” means a part which is designed to replace a group of original equipment parts
and which is functionally identical of those original parts in all respects which in any way affect
emissions (including durability). A consolidated part may qualify as replacement part.
CCR Title 13 § 1900 (b) (2)
Consolidated parts do not require a CARB exemption to be installed on vehicles in California.
further on in the document it states
For the purposes of a Smog Check inspection, the following parts and emission
control changes are acceptable provided that all of the required emission
controls are connected and functioning. When conducting a Smog Check
inspection, it is not necessary to check for a CARB Executive Order for the
following:
Any emissions related part marketed by the parts manufacturer as a replacement for the original equipment.
Am I reading too much into tehis doc....
The VARARAM just like the OEM maintains the air tube and differs only in where the air enters the system.. ie all emission controls ARE connected and functioning.. therefore the VARARAM is defacto exempt from requireing a CARB number.. its emmissions netural!
http://www.bar.ca.gov/80_BARResources/ftp/pdfdocs/Reference%20Guide%20Final%2012-09%20V-2.pdf
Old Feb 15, 2010 | 12:02 PM
01ssreda4's Avatar
So you can go tell that technician to kiss it.
Old Feb 15, 2010 | 12:03 PM
~JOSHUA's Avatar
Glad I don't live in Kalifornia....
Next year go to a different place with your findings printed out if they raise a flag.
Sucks you had to do all of that extra work.
Old Feb 16, 2010 | 01:42 PM
SS DNA's Avatar
Yup! California is BS!!!!
Old Feb 16, 2010 | 03:39 PM
Cole Train's Avatar
I'll take my 5 months of Winter of that crap ANYDAY
Old Feb 16, 2010 | 04:06 PM
scramblerman's Avatar
Damn cali sucks for emmisions!!!
Old Feb 16, 2010 | 06:30 PM
sstg's Avatar
And Earthquakes.Lol.
Old Feb 16, 2010 | 06:45 PM
95CamaroLS1's Avatar
That would bug the hell out of me if you couldnt modify your exhaust and had to be within there restraints. BS
Old Feb 16, 2010 | 07:18 PM
Z28_LT1's Avatar
Yup, bs,..but theres always a way around everything without having to do an intake swap...
Old Feb 18, 2010 | 12:42 AM
TorqueHappens's Avatar
I got lucky and passed smog just fine w/ my Vararam/PowerDuct combo (I removed all the stickers)
Guess the guy just didn't notice or care
Old Feb 18, 2010 | 02:36 AM
BAD-GTO's Avatar
that sucks I passed smog with flying colors in my car and i dont even have cats. I also live in cali.
