Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
underdrive pulley
Old Jun 23, 2010 | 03:27 PM
camaroracer91's Avatar
Default underdrive pulley
What's the easiest way to install this?
Old Jun 23, 2010 | 03:55 PM
scramblerman's Avatar
Well there is no easy way to install the pulley without pulling out the steering rack.
Old Jun 23, 2010 | 09:47 PM
99FRCTorchRed's Avatar
It is a bitch........
Old Jun 23, 2010 | 11:12 PM
NoTractionLS1's Avatar
GL and I tried finding a DIY for this but no dice. This is why im doing this when I install my cam in the next few weeks!
Old Jun 24, 2010 | 09:42 AM
~JOSHUA's Avatar
When you have the rack out, and you're ready to pop the new pulley on.... put the pulley in the oven for 20 minutes at 200 degrees.... yes, I'm serious.
Put a new crank seal on the timing cover before you install, the original probably has a hardened texture and is worn a bit from riding on the stock one forever. The heat from the oven will not harm the rubber seal, the engine metal gets up to 200 degrees anyway... it's normal.
The oven will expand the metal on the pulley which makes drawing it onto the crank much easier... put a light smear of anti freeze on the crank before while the pulley is in the oven. Use oven mitts or leather gloves to carry the hot pulley, get it started, and torque it down like it was a high priced *****.
Old Jun 24, 2010 | 11:06 AM
IAmTheSTIG's Avatar
he means anti-sieze, not anti-freeze.
Old Jun 24, 2010 | 12:40 PM
~JOSHUA's Avatar
Ummm. yeah.
It's amazing what a 40oz of beer on the way to work will do for your thoughts...
Old Jun 26, 2010 | 12:59 PM
How about a little salt and pepper for the pulley..........lol
