Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Did 03 Corvette ZO6 Valve Springs Come In black?
Old 09-05-2010, 03:51 PM
1Ls1's Avatar
Exclamation Did 03 Corvette ZO6 Valve Springs Come In black?
Seen someone selling a 03 ls6 cam and stock valve springs, but the springs were black, i thought they were yellow? can they come black in a 03 zo6? also how would i know if its a true ls6 camshaft?
Old 09-05-2010, 04:46 PM
raven154's Avatar
If you can get a part number off the cam that will tell you what it is.
Old 09-06-2010, 04:16 AM
SCM_Crash's Avatar
They're yellow from what I can recall. I don't remember any of the 02+ LS6s having anything but yellow springs.
Old 09-06-2010, 08:35 AM
scramblerman's Avatar
well the springs are black but they do have a yellow line that looks like it was spray painted from the bottom to the top. These were from 02-04 Z06's, not sure about the 01's tho.
Old 09-06-2010, 12:31 PM
NoTractionLS1's Avatar
Blue Spring = 12565117 Gm Part number
Old Yellow = 12565313
Current Yellow = 12586484 (the one you want)
Note that the above numbers are the single spring part number and that if a set is needed, it is a different number for a complete set that normally will cost less compared to single price.
The blue spring used a wire size of 5.10 x 4.00mm
The later springs (yellow) use wire size 5.25 x 4.34mm
Quick Reply: Did 03 Corvette ZO6 Valve Springs Come In black?
