NOW AVAILABLE: Tick Performance Adjustable Clutch Master Cylinder Kits for C6 & Z06
THIS IS THE KIT YOU'VE BEEN WAITING FOR! The first batch of 20 Adjustable Clutch Master Cylinders for your 2005-2008 Corvette are now available. We don't expect our next batch until mid to late September, so if you're in the market now is the time to buy.
Tick Performance and TICKshift.com proudly present the first and only Adjustable Master Cylinder available for C6 Corvette that provides increased fluid flow over your weak, anemic stock master cylinder. This means you have the ability to fully disengage any clutch available, resulting in quicker shifts and longer lasting clutch and transmission parts. This kit is the answer to the numerous clutch related problems that C6 Corvettes experience all too often.
Our Tick Performance C6 Adjustable Master Cylinder Kit ships complete with everything needed to install, including: our custom Tilton Adjustable Master Cylinder, our Unrestricted and Heat-Wrapped Clutch Hydraulic Line that couples to your existing slave cylinder line (eliminating the need for transmission removal to install), all necessary hardware, and easy to understand instructions.
Our C6 Adjustable Master Cylinder Kit will increase pedal pressure at a bare minimum, makes clutch disengagement issues a thing of the past (with ANY clutch), uses a simple turnbuckle adjustment system and estimated install time is 2 hours (very minor drilling required). Like all of our adjustable master kits, we warrant this unit against failure for the entire time you own yours.
Our kit in it's basic form DOES NOT require removal of the transmission. If you want to eliminate the bulky OEM quick disconnect fitting and the factory steel & expandable rubber line that connects to your slave cylinder, we offer a full-length stainless braided line that comes heat wrapped to couple our Master Kit directly to your stock slave cylinder. This line provides the best, most unrestricted connection, but requires transmission removal to install. Don't forget our new C6 Remote SPEEDbleeder Line while you've got the transmission out - sold separately.
Get in on our first batch here: http://www.tick-performance.com/c6firstbatch/
Please post up, PM or call us at 704-660-5843 with any questions you may have. Thanks in advance folks! :flag:
