C5z Auto Conversion Questions
Either way, it's about the same price.
Your net cost for a built auto conversion is probably $10K net. I've done the conversions both ways and it's a lot easier to go from an auto to six speed than the other way.
Most of the work is in the wiring up of the PCM and transmission controller in the enging compartment. You could get away from this by adding a TCI transmission controller to the install.
The conversion, is not really as bad as it seems. It just takes some patience and a couple of schematics.
You could also by a standalone transmission controller from TCI so that you could by-pass the rewire job.
How does it perform? It always hooks up and never experiences wheel hop. And the best part is that aside from a rebuild of the trans after 463 drag runs, there has not been a single failure.
You can get a great trans and associated conversion hardware from RPM.
The total cost really depends on how much you are able to get for your T-56 trans, existing clutch, etc, and how much you pay for labor.
I think by the time I sold off my stick gear I was into it for around $5K, which really isn't bad at all.
I had the conversion done 3-4 years ago, and I don't regret it for a second.
