No tire pressure sensor on the dash?
He says the front left pressure sensor isn't showing up on the guages...
Does that mean its dead? or it needs to be relearned?
any help would be great so he can leave me alone
thanks
I bought a set of used wheels, tires and sensors. Two of them were dead, one was flaking (took forever to start reading), and the 3rd worked.
It will guide you to a tire, hold your magnet over the sensor area (under the valvestem). When the horn honks go to the next tire and repeat.
If the horn never honks, the sensor is toast or your magnet is not big enough.
You dont have to follow the order of the DIC, so if you suspect the magnet try it on a known good sensor first. You can start over in the right order once you figure out how to do it.
