VA Speed 427 makes too much power...
No vacuum pump. The valve covers vent into the downtube. Even with no baffles in the valve covers the intake stays bone dry. A testemant to Shawn's skills. My 403 (no Shawn built) had a ton of blowby and I worked hard to vent it. Finally ended up with a filter on the oil fill.
#36
so the ? is do the wider street tires hook?
Kevin, that vette is amazing! Just please buy the new Nitto NT05R's and then you will start a new thread titled...VA Speed 427 grenaded my rearend cause my new fat and sticky drag radials hooked like nothing I've ever tried.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#37
...only not enough traction.
You can run the widest tire in the world, if it's not R-compound it's a waste of time. Been there done that on several cars.
The problem with drag radials is I like to run the back/mountain roads around here much too quickly for a drag radial. I tried the ET Street II's and it was horrible.
