VA Speed 427 makes too much power...
#42
Looking at your vette I can tell you've got LOTS of money in it and it deserves great traction. I've got the answer you've been waiting for then.
http://www.tirerack.com/tires/tires....TCUP&tab=Sizes
#45
Thanks guys. I will probably end up throwing R888's on or maybe something else that's come down the pike.
DOWNTUBE???
The valve covers vent into the 4 inch downtube which replaces the stock airbridge. I had to lay the radiator down to do it but it solved an intake restriction issue where I was pulling 7-8 Kpa at full throttle.
DOWNTUBE???
#49
I have a 04 z06 with cam and 90mm intake, rear end brace and 305/35/18 nittos on the back. It has been lowered front and rear. I cant get it to take off without blowing the tires off at the track. Im thinking about a coilover kit for front and rear. What is your car got for suspension running in the 8s?
#57
DOWNTUBE???
DOWNTUBE???
