Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Drag Racing A Vette
Old Mar 1, 2004 | 10:13 PM
2000WhiteTA's Avatar
Default Drag Racing A Vette
In the process of selling the Trans Am and buying a vette. What breaks when you put slicks on a vette. What are the weak links in the rear end.
Old Mar 1, 2004 | 11:28 PM
Texas-FRC's Avatar
I think the weakest link is the output shaft.
Old Mar 2, 2004 | 07:14 AM
Ling_650vette's Avatar
Well, there are two A4 (4L60E/65E) that were M6 cars that ive seen that're running fairly stock systems. The two cars im refering too are Major Spray on this sites, and the Lingenfelter TT 427. Majors car runs an 9.2x while the LPE car runs an 8.95 and to my knowledge, their rear ends are handling the power which aint no tiny #
Old Mar 2, 2004 | 08:16 AM
99hardtopc5's Avatar
install the billet output shaft in the rear diff and you should be ok
Old Mar 2, 2004 | 09:52 AM
enderz06's Avatar
My stock clutch did not like the ET streets vary much on my 02 Z06
used them 3 time ran an 11.98 and have not run them sence. I would sell them if you were interested
Old Mar 2, 2004 | 12:39 PM
c5ls1vette's Avatar
Get hardened output shaft you will be fine. The bearings in that rear end are almost the size of a Dana 60, they are huge.
Old Mar 2, 2004 | 02:06 PM
boos2's Avatar
If do a lot of drag racing, sooner or later your tranny might go if you have an A4.
Old Mar 2, 2004 | 09:56 PM
66ImpalaLT1's Avatar
Major Spray does not use a 4L60E, he uses a Yank TH400.
I second the clutch, I smoked mine on drag radials.
Old Mar 3, 2004 | 12:25 AM
98UltraZ's Avatar
Usually the output shafts.... clutch for m6's, auto tranny.... But if you get a hardened ouput shaft on the driver's side and dynotech engineering has made a new piece that stables the rear more ($400 for the stabilizer, and roughly $1500 for the rearend with gears of your choice and a hardened output shaft)..... They were saying that they launched off the limiter all last summer and fall and never broke anything. Good luck, and trust me you will definitely enjoy the vette a lot!!! I really like mine a lot!!!!
Old Mar 3, 2004 | 08:24 AM
Maybe i was mistaken, but the article i read said after the TH400 was drinkin fluid, he switched to a 4L60E, unless he's either switched back, or i read the article wrong.
Old Mar 5, 2004 | 02:47 AM
Brian Tooley Racing's Avatar
There are two output shafts in the rear, if you make 500+ RWHP you will need to replace them both, the long one is the most common that people replace, but the short one that has a gear made on to it needs to be replaced also. Buy a A4 car and send the trans to Rodney @ Transmission Specialists or Rossler to have is beefed up.
