c5 408 oil pan issue
Oh and i did search the forum before I posted just couldnt find the right answer I guess, so dont bust my ***** on that.
Thanks
Eddie
I'm working on an ERL 434ci for a C5. The MAST tray clears the rod bolts and works rather well with the C5 "batwing" pan (2-piece version). I did some very minor massaging to the tray to make it all fit...
Their tray doesn't require any spacers. I used the washers/spacers in the main stud kit as a buffer for the windage tray nuts (to keep the serrated flange nuts from tearing up the tray). Using some "mach"-up washers I found that were the same thickness as the compressed gaskets, pickup-to-pan clearance is right within spec.
I can't recall what I paid for the tray, but I see it goes for around $80 now.
http://www.coloradospeed.com/index.p...ducts_id=14987
