Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Revised GZ Motorsports Vacuum Pump (C5)
Old 10-02-2012, 06:14 PM
pittman's Avatar
Originally Posted by nhra686
Rebuilds run $100-$150 depending on what we find when we open it up. We always give you a call with our thoughjts on whether we should replace everything, or just the wipers and springs. It just depends on how much wear we see. It has a lot to do with whether the pump is getting sufficient oil to keep it lubricated.
The Z06 shop car has 17K on the pump. We looked at it at 15K, and it showed no wear, so we stuck it back in there. I ran a VP104 pump on our pump dyno for 500 hours and it only showed about .005 wear on the wipers, but it was run under great conditions.
I will start checking in here to answer vacuum pump questions, so fire away if you want my opinion on things.
Bill Huntington GZ Motorsports
Thanks for the info Bill. Great, high quality product.
Pitt
Old 10-02-2012, 07:33 PM
Mike Morris's Avatar
So Bill do a lot of LS daily drivers use these? I don't daily drive my car but its set up so I can drive it anywhere when I feel like it.
Old 10-03-2012, 03:38 PM
nhra686's Avatar
We sell a lot of LSX kits. Most of the kits we sell go on street cars. If you have a "undressed" LS motor, we can set it up to mount on the cylinder head like a SBC. We also have a drive mandrel specifically made for LS motors, so you can bolt it to your damnep and install any pulleys that you require.
Old 10-05-2012, 09:27 AM
baezi z06's Avatar
Originally Posted by RLS!
I didn't like how the 22.5" belt, which came with the LSx kit, set the pump/inlet fitting so close to the coolant reservoir. After some searching, I found a 21" belt.
i have a GZ pump on my C5 vette and i need a new belt , would also like it a bit shorter, it´s rubbing the coolant reservoir
where can i get a belt, do you have any partnumber ...
thanks
Baezi
Old 10-05-2012, 10:33 AM
nhra686's Avatar
The standard belt we send out with a 46 tooth pulley is 22.5" long, 3/8" pitch, 1/2"wide. Gates "powergrip" part # 225L050. The 225 in the part# is the length, the 050 is the width.
I've bought similar belts from Grainger or McMaster-Carr. They are listed as "timing belts"
The best solution is usually a slightly shorter serpentine belt. It moves the tensioner over and creates room. For some reason, the clearance varies from car to car. We don't know if it is serentine belt stretchor what, but the 22.5" belt is usually the best one, but not always.
Quick Reply: Revised GZ Motorsports Vacuum Pump (C5)
