Pics of my C5Z since completion...
#41
#42
Well, a major update and change of plan....
First, I have a new G Force mainshaft coming and I have my local T56 builder is going to go thru the trans and check it all out, replace anything it needs and install the new shaft...
Second, I bought a new 3 rib housing from GM along with new seals/o-rings, C6 pinion support and JDS99 is going to build me a whole new diff using my C6Z guts and DTE hardened shafts...
Third, I just bought an entire auto conversion (RPM Level 7) with ALL of the goodies and will be picking it up this weekend.....
*RPM Level 7 tranny w/brake, all fresh.
*Coan 3600 lock up converter
*SFI flex plate and SFI bell housing
*DSS 3.5" driveshaft and RPM poly bushings
*PCS Tranny controller
*Big *** tranny cooler and AN tranny lines
*Built diff with ECS/Eaton billet carrier/hardened shafts
*ECS tranny brace and Pfadt diff mount
*Shifter and other conversion BS.....
I will be selling all of my rebuilt 6 spd stuff, RXT, Tick MC, B&M shifter, torque tube etc etc after I get everything out and together.
I will update the thread with pics and info as I progress on... I can't wait... Hopefully this turd will go some 9.20s@150 after the swap...
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#46
First the 4l80 is huge and you have to cut the **** out of the tunnel and floor boards...it's a lot of fabbing to get an 80e in a C6/C6.
Second is the weight, the 4l80 and its supporting stuff is heavy as ****, probably adds 100-150 lbs over an M6.
Third is the parasitic power loss of the 80e... That big sucker gobbles up some power and I don't want to lose any more then I'm already giving up by going to an auto/converter...
There is C5s/C6s running high 8s on RPM level 7 4l60s so I am pretty confident it will hold up... Especially since ill only make 20-30 passes a year..
#49
Update....
Started the auto swap. Also gutted the interior so I can install the Wolfe 6 pt roll bar and wire up the PCS tranny controller..
Back in pieces again...
![](http://img.photobucket.com/albums/v245/ZXALAN/5C4C9D80-BEE4-47AC-8B58-CD6479962E2C-1700-000003DC225E32B3_zpsea9267d2.jpg)
![](http://img.photobucket.com/albums/v245/ZXALAN/66A2397F-650A-4906-BFA9-4E0D5523305B-1700-000003DC3498F7C9_zps7fb8da69.jpg)
![](http://img.photobucket.com/albums/v245/ZXALAN/1C5DF70B-099B-48E1-AA7D-DF88B4BAABCC-1700-000003DC426DB7A7_zpsbfc416fb.jpg)
Gotta get it all ready so I can get this bad boy up in there...
![](http://img.photobucket.com/albums/v245/ZXALAN/5D087E20-472E-4C2F-B1B4-13BD8EEA2F90-1700-000003DC05026D7C_zpsfcee30f6.jpg)
Ended up with this mess...
![](http://img.photobucket.com/albums/v245/ZXALAN/11E9B58F-87DD-474B-B91A-0FF9C65C923D-1700-000003DC136185AE_zpsbc39e5a1.jpg)
So DAY 1 summary:
Gut interior, remove Tick MC and clutch pedal assembly, remove manual TT, RXT clutch/flywheel... Got the pilot bearing out. Had to remove the headers which sucks..
Also got the new SFI flex plate installed and the Quicktime bellhousing.. What a bi*ch that was..... Freakin bell housing bolts ate my freakin lunch...
I wont get to work on it for a week or so..but next up will be wiring the PCS controller, run the harness to the tranny tunnel, install tranny lines/cooler, install shifter....finally install the main hoop on the roll bar and start that PITA project...
Slowly but surely...Hopefully I have it running in a month or so...
So DAY 1 summary:
#54
Thanks guys..
Making a little progress... Got the new diff back from Jon and got it all together..
Fresh out the oven:
New GM 3 rib case, GM 3.42 gears, Eaton Trac-Aide differential with 300m shafts, C6Z billet pinion support. Blue printed to perfection by Jon (JD99)..
![](http://img.photobucket.com/albums/v245/ZXALAN/81B86A42-A153-47D7-8486-431854B06C58-5288-00000C9CA81E9866_zps6a0929c2.jpg)
![](http://img.photobucket.com/albums/v245/ZXALAN/39A26A12-74CB-4425-B560-9B485341C58A-5288-00000C9C9C0C2801_zps4b37fb96.jpg)
![](http://img.photobucket.com/albums/v245/ZXALAN/D644154F-1151-47CA-8CE5-664B4C28B9A2-5288-00000C9C82E86896_zpsbdd14871.jpg)
Here with the 9.5" Coan "3600" converter with billet front cover
![](http://img.photobucket.com/albums/v245/ZXALAN/52A387D8-0129-45FD-B6C3-80DB1DC61163-5288-00000C9C79D24308_zps048c66fe.jpg)
Just gotta fill it up with fluid and its ready to go in..
![](http://img.photobucket.com/albums/v245/ZXALAN/FFFCF450-F5DD-4CF1-BD9B-0917ED15F65A-5288-00000C9C704CAB57_zps3f4cbdbb.jpg)
Hopefully next weekend I'll have time to stab it in there...
Slowly but surely its coming together.. I also got the 6pt bar installed and 90% of the interior back in.. Hopefully it all works correctly..
Fresh out the oven:
#56
RPM auto swap complete. I still have some fine tuning to do on the shift parameters and now apparently some engine tuning to do as well at part throttle/steady cruise, but its running again..
Tight fit with the 3" Catback for sure..
![](http://img.photobucket.com/albums/v245/ZXALAN/ED4DBE8C-9F56-43F3-BA53-1ACC5A19AEDD-14562-00002A6B3AE2402E_zps1fb883c1.jpg)
![](http://img.photobucket.com/albums/v245/ZXALAN/190FBC41-691C-46C7-8DD5-96520C34824D-14562-00002A6B4B675C63_zps396adbad.jpg)
Big a$$ tranny cooler installed..
![](http://img.photobucket.com/albums/v245/ZXALAN/765F505B-1AFE-4CDC-BAC0-AC0ECF34EF51-14562-00002A6B8DE163B7_zps17d10da4.jpg)
Looks like a factory installed auto inside
![](http://img.photobucket.com/albums/v245/ZXALAN/32ECCB84-CCD3-4C6C-AB19-C2FAB245AA1D-14562-00002AC4AB827835_zpse9708ff2.jpg)
Tranny shifts VERY firm at part throttle, I love it. The 3600 Coan is pretty damn loose around town, its pretty much 2500-2700 rpms all the time when accelerating with traffic, definitely makes some serious noise with the F1r and twin BOVs.
Also, I have to throw props out to Todd @ RPM Transmissions. I called him atleast 4-5 times with questions and he took the time to help me every time, even though I bought the conversion second hand..(its about a year and a half old)..
I'm glad to finally have an RPM Trans product.
Hopefully I can get it all dialed in and cruise the car for the summer, then in the Winter, I will get it to the strip and start shaking it down.. Hoping for some 9.20@150+ after all is dialed in..
#58
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
