gain of +11.75HP/14.0TQ From just wires
Follow along as we baseline our 2014 C7 Corvette Stingray on our dyno and install a set of our "0" OHM ignition wires (28-1545HTRB). After changing the wires, we noticed an average gain of +11.75HP/14.0TQ.
For question or to order call:
805-486-6644
Direct OEM replacement, exceeds OEM specifications, OBD-II computer safe
Increase power to the spark plug up to 400% over stock
Customers have reported up to 15HP (normally aspirated) & 35HP (s/c, turbo, & nitrous). Average gains on an otherwise stock motor are 5hp N/A and 12 to 15 with factory forced induction
0 Ohm resistance, no RFI / EMI interference thanks to patented protector ring
Patented* design works with all fuel injection systems, street cars and race cars
Solid stainless connector cable with stainless snap lock spark plug connectors
High temperature silicone boots, 8MM jacket with fiberglass-reinforced braid resists temperatures up to 500 degrees f (1200 degree f. boots optional).
Ideal for use with aftermarket headers and/or turbocharger systems
Includes all necessary hardware
Over 600 fitments!
* Granatelli O ohm wires are patent protected by United States Patent number 7,185,622. This patent covers our unique method of producing ignition wires of extremely low resistance while maintaining very high noise suppression. The benefit of this invention is that full electrical energy from the ignition source is transmitted to the spark plug. The end result of the application of this method is increased horsepower, torque and fuel economy.
Over 600 fitments!
What is the difference between the 3 different prices? Which would I need for my ls1 vette with headers and blower? They all say "High temperature silicone boots, 8MM jacket with fiberglass-reinforced braid resists temperatures up to 500 degrees f (1200 degree f. boots optional). "
but the 2 more expensive ones say high temp? Thanks
I have a set of these wires and they are the $200 variant with the hi-temp shields. Not only does granatelli stand behind their product with the warranty the wires will make a noticeable difference. I had a set of MSD wires before. Not only did they ohm out all over the place the quality control is absolute crap. I had wires breaking after 1 time of taking them off. I had to send wires back because they ohmed out more than a stock wire!
