Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Scanner won't connect to Z06
Old Dec 3, 2016 | 12:29 AM
Twinchargedlsx's Avatar
Default Scanner won't connect to Z06
I got a 08 z and My hptuners scanner won't connect to it to read codes. I'm starting to think the ecm might be the problem but just got the car so not too sure. It runs fine and the obdII connectors look clean? Please give me some advice thanks
Old Dec 4, 2016 | 04:43 PM
Larry's Avatar
You have to be in the Editor to read your file. Not the scanner. Ignition on, engine off.
Old Dec 4, 2016 | 04:47 PM
Larry's Avatar
Whoops! You are trying to read just the codes. Not sure what the problem.
Old Dec 6, 2016 | 09:59 AM
LT-4Play's Avatar
Check the fuses - if you popped the fuse you would't have power at the OBD2 port.
Old Dec 6, 2016 | 10:42 AM
OBD2 has power no fuses blown
