Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Installed new opti-spark and now won't start
Old Jan 11, 2021 | 07:29 AM
Raylicker's Avatar
Default Installed new opti-spark and now won't start
Hi all, I installed a new Cardone opti-spark and now won't start, When I got it I did the vent mod on it then when I went to install it it wouldn't fit flat against the timing chain cover, even with out the spline shaft attached. It turned out that where the spline shaft when in, the base plate protruded out to far preventing it to fit flush against the timing cover. Because of the mod I did on it, there was no returning it. So i used my base plate and swapped everything over to it and fit fine but now it won't start. I get spark to spark plug and getting fuel to it as I pulled a couple of plugs and they were wet with fuel. At the same time I installed intake, timing chain cover, oil pan, valve cover gaskets alone with any seals. I also adjusted the valve lash too. Could the opti be putting out spark and still be bad? Could the spark plugs be bad now because of fuel on then, even though I changed them a month ago? Please help because of the bad fitment and a lot of time just pulling the hub and bad weather, I have been working on this for three weeks now, please help!!!
.tb_button {padding:1px;cursor:pointer;border-right: 1px solid #8b8b8b;border-left: 1px solid #FFF;border-bottom: 1px solid #fff;}.tb_button.hover {borer:2px outset #def; background-color: #f8f8f8 !important;}.ws_toolbar {z-index:100000} .ws_toolbar .ws_tb_btn {cursor:pointer;border:1px solid #555;padding:3px} .tb_highlight{background-color:yellow} .tb_hide {visibility:hidden} .ws_toolbar img {padding:2px;margin:0px}
File Type: txt
Old Jan 17, 2021 | 05:41 PM
Dragonmedic67's Avatar
Any codes? Cam sensor is my first idea. The connectors are very moisture sensitive and if it's tthe original then I would change it out. Always resort to basic the basics. Fuel, air and spark in time.
