Top Gear (Brits are harsh!)
Here a picture on the Nürburgring GP track, it's the yellow, white and black car:
http://213.69.169.20/privat/corvette...P/P2142021.JPG
I am not rich and bored enough to start with a new car anytime soon.
Till
Do you have the FE4 suspension on your car or just different springs? The Z51 and FE4 have the same size sway bars, but that is where the similarities end.
You don't have to be rich here to own a new model Z06. I paid $42k for a used 04 with 1,000 miles! I have seen an 03 with around 2,500 miles for $38k! C5 prices are dropping due to the C6 coming out. Lots of good deals to be had.
Dean
I bought the car used. It originally had the Z51 suspension, and they had added stiff Bilstein shocks and Hotchkiss sway bars. The handling felt very good and stable, up to the point where it actually mattered. Horrible understeer on corner entry. Shocks way too stiff, resulting in spinning out on corner exit if there was just the slightest bump in the road. Springs too soft, the wheels hit the wheel wells.
I ended up getting a coilover suspension, using Penske double adjustables.
If there wasn't the cost, I would highly recommend this conversion. Just going with the complete Z06 suspension is probably close in performance, and much less expensive.
Just don't go and get very stiff shocks, without getting fitting springs at the same time. If you are on a very smooth track you may get away with stiff sway bars instead of new springs.
Till
