Need help Fast if Possible
Any help would be great
If you haven't already, check CorvetteForum.com. (Their server failed yesterday and has been sporatic today.) You'll find LOTS of comment on the column lock issue.
For a long term fix, there is a recall out on the column lock problem. Check with your Chevy dealer -- the fix is a PCM re-flash. Also, buy a column lock bypass. Very cheap (about $25??) and very easy to install (less than 15 minutes).
Hope this helps.
I also heard they will have to tear the column apart and it would be 450.00. Where can I get this bpass lock??
Thanks,
Jason
Since I had already installed the column lock bypass, and because I also have a custom LS1Edit tune, I won't be taking mine in for the recall. (They have to flash the pcm for the recall)
If it should happen again, turn the key at the same time you give the steering wheel a hard jerk, and it should free up. I had it happen to me about 15-20 times over a two month period before I installed the CLB.
Steve
http://64.233.161.104/search?q=cache...art=3&ie=UTF-8
http://64.233.161.104/search?q=cache...art=8&ie=UTF-8
Mike98SilVert's post has tells you how to unlock it & he also includes a link with instructions on how to install the CLB.
http://forums.corvetteforum.com/arch.../t-858554.html
The car is at the dealer right now...I told them to stop work on it, until I get there and try to unlock it. One thing that I might have overlooked is, when it first hapened and I tried to drive the car, it stalled. I read somewhere the fuel shuts off. Will this still happen even if I try to unlock it by jerking the wheel left and right?
Thanks,
Hope this helps.
Will
Again, sorry for the confussion. I thought you were taking it in to have the computer re-programmed then install it.
Will
