Modified LS1 Rocker Arms(new Bearings)
OK I know some of you out there do not use aftermarket rockers simply because they are a little heavier over the tip. Well we are going to offer a set of modified stock LS1 rockers done by Harland Sharp. The new rockers will have a new trenion and new bearings with provisions for clips so there is absolutly no chance the bearings can come out. They will use the stock rocker bodies. We will offer them on an exchange basis-send in your rockers we will send you a set rebuilt or as a core charge. We can also offer different ratio when it is done change your stock rockers to a 1.8.
Stock LS1 rockers
Harland Sharp trenion
Harland Sharp bearing assembly
offered on an exchange or core charge basis
Let me know what you think and if your interested. Could be available soon.
Thanks and have a great weekend
Nate
Stock LS1 rockers
Nate
sounds great. just wish New Zealand was up with the play, we have to look to Aussie or USA. Then can have problems with delivery and time involved. price would be good to know.
Harland is still in the process of machining the stock rockers for a ratio change it is posible just want to be sure it all goes smoothly. We can do your SLP rockers too.
Either as a kit with all the parts, tool and instructions. With a press the customer can install these himself.
Total rebuid kit $160.00
Or send in your rockers on an exchange basis or for a core.
Kit installed $200.00
Nate
Nate
